Build Advice £850 First Build - Advice pleeaaase!
Discussion in 'Hardware' started by Nubble, 9 Jan 2010.
  1. Nubble
    Nubble What's a Dremel?
    2 Dec 2009
    Hey guys I've been putting together a new build that I intend to buy tonight/tomorrow - it is as follows;
    Does anyone have any recommendations?
    Dont really want to spend more than I am already, and all items must be from scan (unless the items are in stock and I can get next day delivery for as cheap as scan).
    Any glaringly obvious flaws?
    Thanks in advance, Bob
  2. samkiller42
    25 Apr 2006
    All looks good to me.
    Side Note*
    *I don't think you will get Next Day delivery with any company, with the current adverse weather conditions.
    Sam
  3. mycopia
    mycopia What's a Dremel?
    25 Nov 2009
    You will need the titan fenrir brackets for your 1156 setup =- LN29425 (scan)
  4. Nubble
    2 Dec 2009
    Thanks for advice on brackets :)
    Have decided to use Overclockers.co.uk aswell because they have the spinpoint f3 for significantly cheaper...replaced parts are as follows;
    what do you think, an improvement?
  5. Teelzebub
    27 Nov 2009
    I would go for the sata version of the dvd , And get the corsair psu over the ocz one .
    I would'nt buy from overcockers but thats a personal thing , Apart from that looks good.
    I bought some stuff from Scan last week and had no problems with delivery
  6. Nubble
    2 Dec 2009
    is the F3 from OCZ better than the F1 from scan?
    if not, then theres no real reason from me to buy from overclockers and i'll just buy everything from scan.
  7. smc8788
    smc8788 Multimodder
    23 Apr 2009
    The F3 is faster than the F1, go with that - Link.
  8. Teelzebub
    27 Nov 2009
    I think the F3 is a bit Faster than the F1 whether you would notice or not I dont know.
  9. Nubble
    2 Dec 2009
    Okay, hopefully this is the final revision then...
    I'm guessing that the special edition fenrir comes with the brackets supplied, as it says it is fully i5 compatible..
    Any last things to consider, before I make the leap and commit to the 841£ its going to cost :)?
    Thanks for replies guys, much appreciated!
  10. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    The RAM is the wrong type you'll need to switch it for stuff that's 1.65v
  11. wyx087
    15 Aug 2007
    it'll work perfectly fine. running 4 sticks of them in my machine.
  12. Xonar
    2 Nov 2009
    Bought some of the same stuff recently, it worked bit would only clock at 1066Mhz, couldn't get it any higher. Was later told I'd picked the wrong stuff so sent it back for the same type that runs at 1.65v. That one in particular iat 1.8v is for 775 DDR3 boards or AMD based systems.
  13. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
  14. Xonar
    2 Nov 2009
  15. Nubble
    2 Dec 2009
    Ack...
    cant even cancel the order till monday it seems...as it doesnt even appear in my outstanding orders/order history.
    am i right in thinking that this is normal?
    Will have to wake up early on monday then i guess!
    Is this the stuff I need to change it to?
    http://www.scan.co.uk/Products/4GB-...-(1600)-240-Pin-Non-ECC-Unbuffered-CAS-8-BEMP
    bit more expensive than I was expecting...
    does anyone know where i can find it cheaper including next day delivery?
  16. Xonar
    2 Nov 2009
    Wait for my info to be backed up by someone else as i'm not 100% but i made the same mistake last week and couldnt get the RAM you linked to run at it's specified frequency of 1600Mhz.
  17. numanoid
    numanoid Minimodder
    26 Apr 2009
    make sure the fenrir fits in your case first, ive got the huge coolermaster cosmos s case and i couldnt get the side panel on becouse the fenrir stuck out too much
  18. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    As you seem to need a lot of stuff what about a mouse, keyboard, speakers and an OS?
  19. Nubble
    2 Dec 2009
    bit funny though, the mid-price gaming pc in the latest copy of custom PC runs an i5 processor with gigabyte GA-P55M-UD2 motherboard and 1.8v dominator PC3-12800
    wonder how many people have bought the wrong type of memory if this is the case :\
  20. Nubble
    2 Dec 2009
