Case Mod - In Progress »»» POLARity «««
Discussion in 'Project Logs' started by oliverw92, 8 Mar 2010.
  1. Remmes
    Remmes Be One With Your Mod
    24 May 2010
    wow looking good
    but what are those little holes for.. i mean to me it looks like you were gonna run the cables through them.. but now with sleeving etc that's impossible.. o_O
  2. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    can I ask how you replaced the wires on the PSU? Did you re-solder all the connections inside? If so, do you have any pics of that? I've always been daunted by re-soldering inside the PSU and would love to see some finished work of people that have done it so I can get the courage up to try it myself.
    Also, what's the 18AWG for? I know the 24AWG is for the PSU (like the 24 pin connector), but the 18? Fans?
  3. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Thanks Ben!
    You are correct they are for the cables. With a tiny amount of pressure you can still push the cables through the holes with the heatshrink on. It is a perfect fit! However you cannot remove them again, so I'm not putting the aluminium piece on the cable until it is powdercoated.
    I haven't got any pics unfortunately. Basically, I just cut the wires inside the PSU and then soldered new ones on the end, heatshrinking the join. I couldn't be bothered to unsolder them from the inside.
    You have it the wrong way round - the lower the AWG, the larger the wire core. So 18AWG is for molex stuff like the 24pin and 24 is for fans :)
  4. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Fantastic job matey really love these risks in modding lol ;) Mod on mate I just want to see more and more!
  5. mkb
    mkb Minimodder
    2 May 2010
    sexy sleeving there ;)
  6. DeadP1xels
    30 Nov 2009
    drivebay cover makes it look so damn clean!
  7. domthecondom
    domthecondom Noob Modder
    27 Jun 2010
    this is getting along very nicley man :) psu is looking gooooood
  8. Staack
    Staack What's a Dremel?
    13 Feb 2010
    Do you have any pictures of the old and new cables being soldered together? - Or how you did it?
    Thanks.
  9. oliverw92
    15 May 2009
    Thanks AnG3L!
    Thanks!
    :rock:
    Thankyou!
    No pics of that sorry. This is what i did:
    - open up PSU
    - cut off all the cables i dont want (non-modular 8pin cpu, non-modular gpu cables etc)
    - get a new 24pin connector.
    - prepare 24 new cables to the length you need. strip both ends and crimp one end
    - remove a pin from the old 24 pin connector.
    - cut it off inside the PSU
    - strip the end of the wire inside the psu
    - solder the new wire onto the end of the wire from the PSU.
    - heatshrink over the solder joint
    - plug into the new connector in the same position as before.
    - rinse and repeat 23 more times!
  10. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    I must say; the amount of work you put into this to make every detail perfect is amazing! It looks really, really good, even your hardware has been chosen with design in mind. I like it ;)
    One little ting though - I actually liked the 24 pin cable better with just the black wires. It looked more simple. Not that you sleeving isn't good, it couldn't really be any better, but I just liked the look with the bare cables a bit better :)
    Keep up the good work! :dremel:
  11. Chanc3
    Chanc3 What's a Dremel?
    22 Jun 2010
    I know where you live! Expect a visit soon!
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Hmmm, that doesn't sound good or right :nono:.
  13. oliverw92
    15 May 2009
    Thanks very much :) You have a point about the cables. I am still unsure on this myself, and i will just have to see what happens. I may end up going back to bare cables, I just don't know :)
    Uhm, how?!
    Agreed lol!
  14. Nicksen
    Nicksen Danish Kid :D
    16 May 2010
    Freaking awesome!
  15. The boy 4rm oz
    10 Apr 2008
    Some awesome work mate, congrats on all your new goodies as well :D.
  16. oliverw92
    15 May 2009
    Thanks guys!
  17. oliverw92
    15 May 2009
    Update #23 - 06/08/2010
    I have been rather busy for the past week with my entry for the eBuyer case competition:
    The case used to be an £11 Casecom beige steel mid-tower that i have transformed into something rather more attractive!
    Now that it is done I can get back to my main project
    After getting a 3850 for my tech bench I mounted the waterblocks on the 5850s that used to be on the bench.
    I will be powdercoating the nickel backplates gloss white - as much as I like the nickel i feel it detracts too much from my theme.
    Since i am no longer having motherboard blocks, I can now go parallel on my graphics cards.
    Tubing will be shorter than this, i just had these bit as offcuts so thought why not!
    I am in the process of sourcing black o-rings to replace those green ones.
    At the moment i am using threaded extenders to lift the straight compressions high enough to clear the PCB, however i may try and get some normal spacers instead - i am unsure of the look at the moment of the bottom graphics card fittings.
    As i said earlier, the tubing will be shorter than i previously showed. You can see that in this pic.
    I think having the backplates white will balance out the motherboard area a bit more - at the moment it is dominated too much by black.
    And here you can see how the quad rad from down below will connect up to the lower graphics card.
    QUESTION! White connector, as shown, or black one? I am leaning towards getting a black one.
    mars-bar-man likes this.
  18. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Just saw all these photos over on Overclock.net...
    Still picking my jaw up off the floor...
    Truly incredible man!
  19. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Well,Well,Well! Oh so pretty. looks positively beautiful!I think I'm gonna cry.:waah::hehe::rock:
  20. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    Hot damn those pics are sexy :jawdrop:
