Case Mod - In Progress »»» POLARity «««
Discussion in 'Project Logs' started by oliverw92, 8 Mar 2010.
  1. Nicksen
    Nicksen Danish Kid :D
    16 May 2010
    Awesome :D - Everything needed is now said.
  2. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Yeah that would be my guess too.
  3. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    One of my favorite mod at this moment:thumb:
  4. earlydoors
    earlydoors Minimodder
    12 May 2009
  5. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Thanks guys :D
  6. oliverw92
    15 May 2009
    Update #27 - 18/09/2010
    Here is some nylon/polyester dye. I could not find replacement connectors for my Enermax Revo, so I used an idea from a friend called Kai on another forum and dyed them.
    You simply put some dye and water in a small saucepan then simmer it for about 15-30 minutes.
    Then rinse it under the tap
    Here is a comparison - old on the left, dyed on the right. Even the cables go black!
    All three together.
    This needs some explaining! I could not get the red connectors off the PSU itself. I tried unsoldering, but i don't have a hot enough soldering iron. I tried heatshrinking the connectors to see if it would look good enough, but no matter what i did the red always showed through. Last resort? Dye the whole thing black then wash off the excess! I took the PSU apart then stuck the end of the modular board in the saucepan.
    As you can see, it worked
    Jump forwards now. No this is not a render, the case is actually powdercoated!
    I also bought my 4x Samsung F3 Spinpoint 1TBs.
    Redid the 24pin in all black.
    Eventually the motherboard backplate will have snap caps on the screws, just like the PSU plate.
    I've started doing a little cable management. Going well so far.
    Here is the 24pin
    The completed power supply. I am VERY happy with it!
    I decided to dry fit all the components. Everything is fine, thrown up one problem - my crossfire bridge hits the backplates on the GPUs. Should be able to sand down the connectors on the bridge to fit though. Also the bridge looks really really dodgy. Need to try and remedy that!
    I leave you with this :)
  7. General_Confusion
    General_Confusion Now Where was I?
    3 Jul 2010
    Verry nice, Very clean :thumb:
  8. stonedsurd
    11 Mar 2009
    Looks wonderful!
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Wow dyeing in a saucepan, can't say I've seen that done before, especially the shot with part of the psu in liquid, I trust you know what you're doing though mate :), excellent results from it :thumb:.
    Looks brilliant powder coated, perfect looking braiding too :), looks fantastic :rock::thumb:.
  10. The boy 4rm oz
    10 Apr 2008
    Really interesting dye job, it looks great though. The entire build is looking great. I can't wait to see it all together.
  11. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Wow nice dye job matey and really clean cable management! Mod on!
  12. bulldogjeff
    2 Mar 2010
    WTF is going on round here? a while back 1 bloke was roasting his GPU in the oven, now you go and boil your PSU. Is this a computer modding forum or a cookery club?..:D
    Thats a wicked idea for dyeing the plastic, never seen it done before looks good.
  13. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    Looks awesome Oli,can't wait to see it all tubed up :rock:
  14. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Excellent!:D Nice trick with the dye too:thumb:
  15. Remmes
    Remmes Be One With Your Mod
    24 May 2010
    that unneeded RAM block kinda will ruin it i think..
    other than that, looks very Cheesecake , loving the white n black
  16. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Some guy have the gut to do what their mod need. dying the PSU in the saucepan seems crazy (in a good way) to me.
    What next dismounting the mobo to dye PCI-E connector in white and black?
  17. oliverw92
    15 May 2009
    :rock:
    I think i know what i'm doing. Sometimes people say i'm a little :lol: though :p
    Thanks oz :D
    Mod on brother :D
    Did you not see? This thread is now called 'Cooking with Oli' :p
    :naughty:
    Thanks Loose :)
    Nah i think the ram block will look perfect. It bridges the gap between the CPU and the RAD and it also makes a change to the standard boring Corsair Dominator heatsinks.
    Hahaha :p I wouldn't have the guts to do that to a £300 mobo!
  18. General_Confusion
    3 Jul 2010
    But you did think about it didn't you? :D
  19. oliverw92
    15 May 2009
    Oh yes of course :p
  20. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    :jawdrop::jawdrop::jawdrop: Juicy!!!
