Case Mod - In Progress »»» POLARity «««
Discussion in 'Project Logs' started by oliverw92, 8 Mar 2010.
  1. Nicksen
    Nicksen Danish Kid :D
    16 May 2010
    Any updates? Or are you too busy with the school? :)
    Looking forward for updates <33
  2. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    Very very busy, I might have something soon :)
  3. Nicksen
    16 May 2010
    Good :)
    - Nice work :D
  4. oliverw92
    15 May 2009
    Update #14 - 24/05/2010
    Got a new toy - Canon EFS 60mm f2.8 Macro!
    I remade all the hard drive trays - I wasn't happy with the original design and I also realised there would be masses of vibration.
    To solve the vibration issues all the holes have rubber grommets in them (this also elevates the hard drives meaning they don't actually rest on the acrylic at all and the screws that go into them don't touch the acrylic either). I have also lined the edges of the base of the plates with neoprene. This creates a tight friction fit between the rails and the tray.
    I'm hoping this should be enough!
    Here is a 2.5" drive mounted on one of the trays.
    The drive doesn't actually make dwww.oliwali.co.ukct contact with the acrylic.
    And with a full size drive on.
    Quick test fit - these are all just test drives so i can check dimensions etc.
    Bought an SSD second hand a few weeks back. It died unfortunately so i sent it off for an RMA, got a brand new one back!
    It's a Corsair Extreme 64GB (Indilinx Controller)
    Tightening it onto a drive tray
    Got some laser cutting by a friend. This is a plate i have had done to tidy up cable management and also mount the res on.
    The use of these holes will all become clear!
    Still got to cut out some holes in the mobo tray - the new Dremel I got back from repair was dead on arrival!
    Pretty tight fit with the hard drive bays!
    And with the res installed.
    Should be getting some white tops for the res at some point.
    Here is the plate behind the motherboard tray.
    Hmmm why am I installing the CD drive...
    Oh yeah that's why! This is my custom faceplate that stealths an FC5 and a CD Drive.
    This tab is the button for the CD drive - inspiration taken from MurderMod.
    Here is the blank installed over the CD drive.
    And to fill the gap for the fan controller, Lamptron have joined the project! They are sending me V2 of their FC5 fan controller, which fixes the viewing angle issues of the first version.
  5. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Hey Oliver, can I ask a favor? Would you mind posting the dimensions (H x W) of your replacement front panel? I've got to make one for a friend, but he hasn't received the case yet and can't get me the measurements. I'd sure appreciate it!
  6. DeadP1xels
    30 Nov 2009
    The sex nuff said.
  7. oliverw92
    15 May 2009
    The dimensions of my plate are 150mm x 300mm :)
  8. craigbru
    28 Feb 2008
    Perfect! Thanks man!
  9. skreenname
    skreenname SFF Forever
    11 Jun 2009
    That front plate is brilliant.
    And the Drive trays as well.
  10. The boy 4rm oz
    10 Apr 2008
    Excellent HDD mounts, I must steal that idea :D. I really like the front, nice simple design.
  11. Nicksen
    16 May 2010
    Super work there :)
    Really like the HDD idea :)
  12. Nicksen
    16 May 2010
    Any updates? :D
  13. oliverw92
    15 May 2009
  14. Cheapskate
    13 May 2007
    Sweet faceplate.:D Like the 24 pin wire loom too. I missed that before.
  15. ModaRobby
    ModaRobby What's a Dremel?
    5 Aug 2009
    Cant believe I missed this oliver, especially after reading both of your other logs!
    Sub'd. :thumb:
  16. oliverw92
    15 May 2009
    Thanks Cheaps :D You should check out Clemens the Tech Bench btw Cheaps, acrylic goodness!
    THanks moda :)
  17. Nicksen
    16 May 2010
    Clemens Tech Bench'es are so cool!. Good work.
  18. oliverw92
    15 May 2009
    I'm thinking about getting a friend to make me a 8mm aluminium sheet one at the place he works :p He has some massive CNC lasering and bending equipment
  19. StEm
    StEm What's a Dremel?
    30 Nov 2009
    Im liking how clean this is looking.
  20. oliverw92
    15 May 2009
    Update #15 - 06/06/2010
    Decided to take some overall pics of the case to give you a general idea of what stage the PC is at. I have also now finished up the motherboard tray except for one more hole, and I realised today one of my cuts is SO not straight.
    My new lens makes the TJ07 look soooo sweet
    That's all folks!
