Largest Home PC Ever? Please note that this is my first case mod. 50 inches height.(without the wood/castor wheeled base). 18 inches width/depth. ... These are teaser pics only. 2 corners are spot-welded to each other. I have to Dremel these out. This may take some time. Don't expect updates soon, or very often. Next couple of weekends are booked for the cottage (before the water gets too cold to swim in.) Project name courtesy of Stuntman @ TwistedMods.
HOLY CRAP THATS GOTTA BE THE BIGGEST CASE IVE EVER SEEN lol its almost as tall as me!!!!!!!!!!!!!!!! im like 5' 2 or 5' 3 id call it HUMUNGO!!!!!!!!!!
It's actually gonna hold 2 separate PC's. I'm transferring the wife's Dell Dimension 8100 into it, and then all the components of my PC (when I buy em) are going in as well.
Sooooo?? then your making it huge just for the *** of it then right.. unless there will be like 5 water cooling loops in it I see no reasion for it's size. But cool non the less
Count the slits down from the top. At slit #5 I'll be putting in a "ceiling" and will have a lamp or something inside above that to give off ambient lighting to the living room. From that point down to about the 10th or 11th slit from the bottom will be the computer housing. Whats left at the bottom will be whatever I want. We live in a small apartment, and our current desk setup takes up a huge amount of space. Almost double that if I were to get my comp built and my desk set up. This tower will allow us to get smaller PC workstations because we dont need extra space to hold 2 cases.
For those curious as to what it is, it was a unit that Reebok put into select SportChek stores for some NBA promotion. We called their rep to come pick them up when the promotion ended but she told us to just throw em out. We had 4, but I saved one.
This is the ultimate anti-LAN rig. It weighs in at 136 lbs. empty! (according to the bathroom scale). It wont be going anywhere.
tow it, thats why it has wheelz!!!!!!!!! id rather bring that to a lan party then a shhuttle, no body could walk off with that oooooooooooooooo you should just stick a monitor in the case, make an "ALL IN ONE" computer it can be your desk, computer, monitor, heck i bet you can fit a chair in there
Wowza! I think the name is quite fitting to the case... I will be interested as to see how you use the space in it... So you say this won't be your LAN rig? Hmm wonder why...
Moved to Modding as per the rules for Project Logs. When you've done some work on it, let an admin or Mod know and we'll bump it back across to Project Logs.
