Case Mod - In Progress 【MSI PRO MOD – S3】 Tifeo B&Warboy
Discussion in 'Project Logs' started by warboy, 7 Dec 2015.
  1. warboy
    warboy Insane modder
    24 Nov 2011
    Hello!
    the idea is to create a mod inspired at msi black and white graphics on motherboard.
    The Spec of this mod are (they may have some variation):
    Motherboard:MSI B150M Bazooka
    Graphics Card:MSI GTX 950 2GD5 OC
    Ram: Kingston HyperX Fury DDR4 16GB 2133
    Power supply: Bitfenix Fury 550G
    Fan Controller: BitFenix Recon
    Fans: Bitfenix Spectre Pro LED white
    CPU: Intel i5 6500
    SSD: Kingston HyperX SHSS37A/120G Savage SSD
    HDD: WD SCORPION BLACK 320 GB 2.5"
    Cooling: Coolermaster Seidon 240
    Keyboard: Thermaltake MEKA G-Unit
  2. warboy
    24 Nov 2011
    Chassis : BitFenix Phenom
    and MSI GTX 950 2GD5 OC
  3. warboy
    24 Nov 2011
    still cuts
    Then I created the cover of power supply on which I put the ssd and HD
    I continued to cut and I plastered a few holes
    I cut some pieces of plexiglass and I airbrush this
    with some stencil
  4. warboy
    24 Nov 2011
    I chage the color to SSD and th Hard disk
    i continued with the change to the chassis
    and with the airbrush
  5. warboy
    24 Nov 2011
    and now beginning to customize the motherboard MSI BAZOOKA B150M
    mask the part of motherboard
    I paint with Plastip the MB and now i airbrush it!
  6. warboy
    24 Nov 2011
    and now start to work with di iron!!
    I cut and welded and after...
  7. warboy
    24 Nov 2011
    after i cut the mesh for power supply
    these are the fans for the aio Coolermaster seidon 240
    this is the waterblock
    and I painted in white
  8. warboy
    24 Nov 2011
  9. warboy
    24 Nov 2011
    and the final photo
