Case Mod - In Progress 【MSI PRO MOD –S5: Demonstration】 ARCTIC Wolf by modding-extreme
Discussion in 'Project Logs' started by modding-extreme, 28 Apr 2017.
  1. modding-extreme
    modding-extreme Member
    8 Oct 2010
    Hello everyone. I am modding-extreme from germany. I am proud to be an judge at this PRO-MOD Season.
    I have modding experience for 14 years and stayed the last years at the german case mod masters as an participant. Many times for example in the live modding challenge.
    So this time i will do an demonstration mod and will do my best. I will use acrylic glass, wood and some more things to create something nice an unique.
    Here the specifications of the mod:
    CPU: AMD Ryzen 1700X
    CPU Cooler: MSI Core Frozr L
    RAM: 16 GB Kingston HyperX Predator DDR4 3000Mhz
    SSD: 240 GB Kingston HyperX Predator PCIE SSD
    Mouse: MSI CLUTCH GM40 Gaming Mouse black
    Headset: MSI DS 502 GAMING
    Keyboard: MSI INTERCEPTOR DS 4200 GAMING
    Fans: Be Quiet Silent Wings 120 & 140
    Thanks to:
    MSI
    In WIN
    Kingston HyperX
    BeQuiet
    Some hardware pics:
    And now, lets start with the mod..... :thumb:
    Ok... here we go... first a drawing on the case i wanted to cut. But there is sometimes an idea... and when its painted on the case.... the idea isnt good any more... ;) ... i decided to cut in an other "design"
    After that, i cut a few parts as spacer.... i will try to get the inside of the case quiet clean.
    By the way.... you will never see cnc or otherwise machine made parts. I do it the oldscool way..... with electric and non electric hand tools ;)
    first the theory....
    and then my little problems with the design.....
    lets do it another way... :)
  2. modding-extreme
    8 Oct 2010
    finally i choose a design and start cutting
  3. modding-extreme
    8 Oct 2010
    after that.... small parts for the inside.....
  4. modding-extreme
    8 Oct 2010
    then i made some templates for the aluminium parts in the inside
  5. modding-extreme
    8 Oct 2010
    so... now its time to cut the parts out of alu....
  6. modding-extreme
    8 Oct 2010
    lets take a look how they fit
  7. modding-extreme
    8 Oct 2010
    Some more pics of cutting of more parts.
  8. modding-extreme
    8 Oct 2010
    after that i prepared the wood side panels
  9. modding-extreme
    8 Oct 2010
    time for painting the case and the side panels.... the side panels got a shabby look in the second paint step
  10. modding-extreme
    8 Oct 2010
    here you can see the difference between first an second paint step......
  11. modding-extreme
    8 Oct 2010
    i integrated the original window in the wood side panel and the original fan vent of the right side panel
