Case Mod - In Progress 【MSI PRO MOD - S3】KRAIT Skin by Watermod
Discussion in 'Project Logs' started by Sassanou, 30 Dec 2015.
  1. Sassanou
    Sassanou New Member
    3 Sep 2011
    Hi !
    With this worklog, I want to show you my work for the 【MSI PRO MOD – S3】:)
    But more important, I'll show for beginners how to do a «good looking » mod without huge budget and with steps by steps works ;)
    So, here we go !
    And first, photos of components I'll use :)
    MSI Z170 Krait gaming + GTX 960 armor 2x thermal edition !!
    And the case I've choose for this mod :)
  2. Sassanou
    Sassanou New Member
    3 Sep 2011
    And here are the materials I will use for this mod, I just want to show to beginners that it's possible to do a mod without a huge amount of money !
    First modification done on the exterior of the case !
    That fits better with Krait colors ^^
    After that the Ram and the Cooler for the CPU have received a new look !
    Some work now on the MSI GTX 960 :)
    Here is a step by step process if you want to create your own backplate and highlight your graphic card !
  3. Sassanou
    Sassanou New Member
    3 Sep 2011
     I also made one PSU cover and here is the step by step process !
    And the final look (miss the screws) !!!
  4. Sassanou
    Sassanou New Member
    3 Sep 2011
    Now, here is a new plate for hide some parts inside of the case and make a support for SSD !
    And the result (90% of the mod is done) ^^
  5. Sassanou
    Sassanou New Member
    3 Sep 2011
    And the result !!!!
    Hope you will like :)
