Development 1&1 and HTTP Auth
Discussion in 'Software' started by ChriX, 1 Aug 2005.
  1. ChriX
    ChriX ^
    30 Aug 2001
    I'm having a problem when using 1&1 hosting, where I cannot get HTTP Authentication to work. The following is a simple bit of code from php.net that should echo the username and password you input. This works fine on my home dev server, but when I use it on 1&1 it just keeps the username/password dialog coming up over and over until you press cancel.
    PHP:
     if ($_SERVER['PHP_AUTH_USER'] == "") {
    header('WWW-Authenticate: Basic realm="My Realm"');
    header('HTTP/1.0 401 Unauthorized');
       echo
    'Text to send if user hits Cancel button';
       exit;
      } else {
       echo
    "<p>Hello {$_SERVER['PHP_AUTH_USER']}.</p>";
       echo
    "<p>You entered {$_SERVER['PHP_AUTH_PW']} as your password.</p>";
    I was wondering if anyone else had come across the same problem, and if so how did you get around it?
    Ta. :D
  2. RTT
    RTT #parp
    12 Mar 2001
    This means that 1&1 are running PHP in safe mode. I think you can use something like $_SERVER['REMOTE_USER'] instead but don't quote me on that ;)
  3. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    safe_mode Off
    that's on my 1and1 account...
  4. ChriX
    ChriX ^
    30 Aug 2001
    Finally got a reply from them and they said it's because they run PHP as a cgi instead of as an Apache module. Oh well...
  5. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    normally when its as CGI istead of apache module, its slower, but run in unsafe mode?
    With my first PHP enabled ISP (Freedom2Surf) i had to use a CGI entry point to avoid safemode? Do you think thats what they ment.
    if its CGI mode at present you'll have to have like #!/bin/php or something at the top of each file.
  6. ChriX
    ChriX ^
    30 Aug 2001
  7. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    hmm i think you could work around this, if you have a .htaccess you can make it parse that, but i can't remeber hwo you dupe it into parsing a PHP file. It can be done.
    Another way would be to force apache to always show the auth box, this can be done with a .htaccess again, that way, it will let them run the PHP script with whatever you type, but i think you can still get the variables. I think.
