1.4 Athlon VCORE
Discussion in 'Hardware' started by NiTr0, 15 Aug 2003.
  1. NiTr0
    NiTr0 What's a Dremel?
    16 Aug 2002
    Lo,
    Just noticed recently that the 2nd PC (Abit KG7, Athlon 1.4) is running a little high on the temps.
    Used the hardware monitor and found that the vcore was being reported and 1.8
    This seems a little high to me and I took it down to 1.7 and the system is still stable.
    Question is.. Anyone know what the recommended vcore setting should be for such a set up?
  2. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Is it not 1.5 m8ty?
  3. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    no, the new .13 chips use 1.5v, old .18 chips use 1.75 default. if its happy at 1.7, use that
  4. NiTr0
    16 Aug 2002
    Cheers.
    I have just ordered a XP2500+ 333FSB Barton for my PC so i assume the vcore for this chip would be 1.5v?
  5. Haddy
    Haddy World Domination
    22 Jan 2002
    Its 1.65
  6. NiTr0
    16 Aug 2002
    Cheers :)
  7. Amorphus
    Amorphus What's a Dremel?
    25 Feb 2003
    however, "Athlon 1.4" suggest to me that he has a Thunderbird core... and that would be about 1.8, right?
  8. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    No because the xp1600 is 1.4ghz
    or did you mean thoroughbred.
    BTW my xp1900 (I think it is a tbred) runs at 1.75
  9. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    think he means voltage
    Default vcore is 1.75
  10. NiTr0
    16 Aug 2002
    Got the 1.4 running stable with the vcore set @ 1.7 the chip is the TBird, and not the XP
    Cheers for the post.
  11. Tim S
    Tim S OG
    8 Nov 2001
    default is 1.75v for a thunderbird.
