Overclocking 1.450v too much for Phenom II?
Discussion in 'Hardware' started by AoE, 16 Jan 2012.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Running a native x4 3ghz 960t, overclocked to x6 4ghz (1600t). Voltage is 1.425v with intel burn test 1500mb, temps are 44/45c, similarly Prime95 gives these also. I tryed going 4.1 without anymore vcore but bsod. So is 1.450v safe for this chip and if so what temps should I be looking at, or rather not to exceed?
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    PhenomIIs are happy up to about 60 degrees, anything over that and you start nudging against the TjMax where the thermal cutout will kick in, you've gotta be careful to stay lower than 60, just in case something causes an unexpected temp spike.
    Generally speaking; i'd say 55 degrees is an okay max temp.
    Don't worry about the vcore. I've put everything up to and including 1.6V through my previous PhenomII, and it did it very little harm from what I could test on my end.
  3. jizwizard
    jizwizard Modder
    24 Dec 2010
    Plenty safe enough mate
  4. AoE
    4 Oct 2011
    Ran P95 for 40mins, max temps 47c and 48c for few secs then dropped again. Will run a 2000mb intel burn test later
    Currently shes sitting like this:
  5. Sheiken
    Sheiken Wat?
    9 Jan 2005
    This
  6. rollo
    rollo Modder
    16 May 2008
    id personally stick to 1.39 or below 1.4 and above is alot of volts
    knocking it back 200mhz and 0.1v is better for your cpu than 200mhz extra and 0.1v higher
    and you wont gain much performance either
  7. AoE
    4 Oct 2011
    Explain as the above 2 posters have stated otherwise? Do you mean in terms of life expectancy?
    Plus I play FSX alot and every bit of mhz counts in that game.
  8. rollo
    rollo Modder
    16 May 2008
    In terms of life epectancy yes
    And above 4ghz the benifits are small to performance gained in games that is a certainty. benchmarks will always show a gain what you see in real terms will not be anywhere near that. very few games run more than 3 cores let alone 6.
    you could knock the .13 ghz of your overclock and go below the 1.4vcore range id expect.
    if your doing photo and video editing your correct that every mhz counts. Temps dont kill your cpu over volting does is the basis of the story.
  9. AoE
    4 Oct 2011
    True, the .13 was automatic with the multiplier, I think therefore it should run fine and I will get benefits from it using FSX. Temps are important though as they regulate a higher voltage better yea? I got another BNIB 960t awaiting incase of the worst, but I wont be overclocking anymore until I get a full w/c rig.
  10. jizwizard
    jizwizard Modder
    24 Dec 2010
    Ran a phenom at 1.6 for two years no probs still going strong in my mates @1.5 with no signs of degradation
  11. sandys
    sandys Multimodder
    26 Mar 2006
    I've run 1.7v through mine but I run water setup, not sure i'd do that with out, when running a long encode it gets toasty with all 6 cores loaded, I wound back my overclock to 4.1Ghz which is happy at 1.45v, the extra volts required for 4.4Ghz just weren't worth it for a minimal performance gain.
  12. AoE
    4 Oct 2011
    ok who thinks I should downvolt and downclock? for the sake of keeping my CPU alive
  13. jizwizard
    jizwizard Modder
    24 Dec 2010
    That voltage your running will be ok for everyday use
  14. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    @AoE I was thinking of buying the same processor, how does it run with the cores unlocked and overclocking, things like games, video and real life tasks?
  15. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    I have this solid as a rock
    Using this for cooling
  16. AoE
    4 Oct 2011
    Brill for gaming, and mulitasking is a breeze, sony vegas editing also a breeze
  17. .//TuNdRa
    12 Feb 2011
    Keeping a Sempron in check isn't exactly difficult, however. Keeping a Hex Core in check at over 4Ghz is dramatically harder. I speak from experience.
  18. AoE
    4 Oct 2011
    Yea I dont think i'll surpace 4.1 unless I got w/cooling
  19. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    You'll be safe if you don't go over 1,55V. If you go over that things might turn out badly.
  20. legoman
    legoman breaker of things
    28 Feb 2010
    Mines happily whiring away with 1.472V shove up its proverbial. Not had it touch above 50 even during stress tests
    4028.78 MHz (236.99 * 17)
