1.5v and 1.35v DDR3
Discussion in 'Hardware' started by Ant1981, 17 Sep 2019.
  1. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    Hello,
    I've got a small form factor Lenovo pc here with 4gb ram and I'd like to add more. The memory installed is 1.35v DDR3-L. There's not a lot out there in the way of 1.35v DDR3 so I'd like to find out if the system will run a 1.5v module. Lenovo support isn't any help and searching online doesn't really find an answer.
    So, if anyone here knows the answer that would be great. Thanks.
  2. Gareth Halfacree
    4 Dec 2007
    A model number might help, but if it's designed for DDR3L then DDR3 likely won't work.
    Not sure what you mean by 1.35V DDR3L being hard to find, though: plenty of it on Amazon.
  3. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    I can find some of it on eBay. When I did a search on the usual suppliers websites there wasn't much on it. Knowing it's DDR3L installed, it's my instinct to use the same, but there's plenty more choice from DDR3.
  4. Gareth Halfacree
    4 Dec 2007
    As I say, if it's designed for use with DDR3L then DDR3 won't work. If it's designed for use with DDR3L or DDR3, then DDR3 will work so long as you remove the existing DDR3L.
    Without a model number, there's no way to know. "Small form factor Lenovo PC" covers about a bazillion different products from the last decade or so...
  5. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    It's an M2929 from the M82 series, but even I couldn't find out using the Lenovo support site. So no idea what the board is 'designed' to use.
  6. Gareth Halfacree
    4 Dec 2007
    Reading this:
    It sounds to me like DDR3 should work fine - but, like I say, you'll have to pull the existing DDR3L. No guarantees, though, but Crucial reckons DDR3 will work fine, too so long as it's 1.35V. 1.5V, though, doesn't look like it'll work.
  7. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    I managed to find some DDR3L, I got a good price for some Kingston ram, two 8gb modules which work fine with my existing 4gb. So I've got 12gb in this i3 3220 and it has made the world of difference.
