Motherboards 1.65V RAM on FM1 ?
Discussion in 'Hardware' started by adam_bagpuss, 30 Jan 2012.
  1. adam_bagpuss
    24 Apr 2009
    hey all,
    just purchased a GA-A75M-D2H and specs says 2x1.5V DDR3 !!
    will i be ok with 1.65V as thats what ive got laying around at home ?
    anyone tested this ?
  2. Whindog
    Whindog What's a Dremel?
    16 Sep 2010
    I wouldn't. Heard some nasty story's about fried motherboards n weird stuff wen running. That was with a Sandybridge system tho. It would b cheaper long term to buy 1.5v memory rather than a new mob n CPU later if it goes bang. Just my thoughts.
    Sent from Bittech Android app
  3. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I am using 1,65v memory with my SB processor and I haven't had any problems. I belive it will only cause problems if you want to overclock your memory further than their specified timings. Sometimes you get lucky and your 1,65v memory will run at their specified timings at 1,5v.
  4. GeorgeStorm
    16 Dec 2008
    I'm currently running my RAM at 1.62ish I think in my setup.
    No problems so far :)
  5. adam_bagpuss
    24 Apr 2009
    that on FM1 george ?
  6. GeorgeStorm
    16 Dec 2008
    Yeah, sorry :p
    I'll update my sig later.
    Currently running at 1860 CAS8 1.65v :)
    RAM makes a huge difference to how a llano setup feels I've found, felt sluggish on the desktop etc at 1333 CAS9, upping the ram, even to 1600 C8 made it feel like a totally different pc!
    You tried clocking your chip? Think I'm going to have a go tonight, see what extra performance I can eek out of it
  7. adam_bagpuss
    24 Apr 2009
    just got the bits today so building tonight after work.
    I may overclock but i doubt i need it since its only for XBMC and the net.
    I was thinking about going linux for it but im not sure on support for FM1 yet ?
  8. murraynt
    murraynt Modder
    6 Jun 2009
    What ram is it?
    Even though my corsair xms3 ram is rated at 1.65v it has no problem running at 1.52 volts. I haven't tried at 1.48 yet but I think that would be pushing my luck.
  9. Guest-16
    Guest-16 Guest
    What RAM is it exactly? 1.65V at 1333MHz or higher? If higher just run it at 1.55V 1333. Tbh though, 1.65V will be fine 99% of the time - see if you can undervolt it a tad maybe if you really need to run it at faster clocks.
  10. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    my xms ddr3 runs fine at 1600 @1.5v, but for 1680 (the fastest i can get it to go) it needs 1.64v,
    but i've never messed around with timings etc.
  11. adam_bagpuss
    24 Apr 2009
    its corsair XMs3 Classic Runs @ 1600mhz 9-9-9-24 @1.65V
    attempted last night a straight auto + 1.50V 1600mhz @ 11-11-11-29 it failed straight away.
    Ill have a play but if it should be fine to run at 1.65V ill try undervolting a little maybe 1.6V-1.62 ?
