Build Advice 1,760.47 $ BUILD help
Discussion in 'Hardware' started by Grib, 23 May 2009.
  1. Grib
    Grib What's a Dremel?
    23 May 2009
    Coolermaster dominator 690 - 76,70€
    corsair tx-650w - 93,30€
    asus p6t se - 194€
    intel core i7 920 (2.66ghz) skt 1366 box - 264,10€
    noctua nh-u12p se1366 - 55,80€
    gskill kit 6gb ddr3 1600mhz pi (cl8) - 100€
    seagate 500gb sata ii 16mb sp (7200.12) - 56,60€
    samsung dvd±r 22x sh-s223f preto bulk (sata) - 19,70€
    bfg gtx285 ocx 1gb ddr3 pci-e - 382,90€
    TOTAL - 1260€ / 1,760.47 $
    Obviously for extreme playing.
    The best for the price,would you change anything ?
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Yes.
    - 1 x GTX 285
    + 1 x GTX 275/HD 4890
  3. bagman
    bagman Minimodder
    18 Apr 2009
    is your computer only for gaming?
  4. Grib
    23 May 2009
    Explain the changes pls.
    Yes basically.
  5. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Ya why weaker cards for a GTX 285?
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    The GTX 285 is nearly the same as the GTX 275 at most resolutions, and the $100 price difference makes up for the small loss in performance.. Look at the Bit-Tech review of GTX 275, it's benchmarked against the GTX 285.
  7. bagman
    bagman Minimodder
    18 Apr 2009
    well then you might as well as get a e8400 gives same performace as i7 as nvidia and cpc have proved then you can get a more high end graphics card. basicly i am saying it is point less having i7 just for gaming as it is a rip off
  8. dec
    dec [blank space]
    10 Jan 2009
    swap the 285 for the 275
    if you are ONLY gaming then save the money and get the e8400 like bagman said
    4gb ddr2-1066 ram
    p5q deluxe motherboard
    the money you save could be invested in something like a bluray drive or a bigger monitor maybe even a 1TB hard drive
  9. Guest-16
    Guest-16 Guest
    It's not weaker. Testing this week and we've discovered Nvidia has optimised the 275 so much it basically equals the 285 in many things.
  10. Nicb
    Nicb Let's discuss among ourselves
    12 Nov 2008
    Personally I would want 2 x 260 in SLI for about the same price as the 285.
    I'm in the USA and with www.tigerdirect.com and www.newegg.com they cost under $200 each.
    Here is an example:
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4539625&CatId=28
    We had a recent review that impressed upon me about 260 in SLI mode:
    http://www.bit-tech.net/hardware/graphics/2009/03/09/bfg-geforce-gtx-285-h2o/3
    I just wanted to add again, my opinion but now after reviewing the 275, I think my post was a waste. sorry :(
  11. Grib
    23 May 2009
    Where can I see that article? The one in the list is a overcloked version of 285 you sure is the same thing?
    Actually I Will use to use some applications like photoshop, Eclipse for programming and maybe some autocad and Maya.
    Oh and forgoy about the 1080p movies.
    I know that actually games and programs only use 2 cores but In the near future I'm certain the will support the 4 and I want this PC to last more as possible.
  12. dec
    dec [blank space]
    10 Jan 2009
    I remeber reading somewhere about someone's video card supporting adobe photoshop acceleration. i think its AMD/ATI but im not totally sure. whomever it is it may be worth looking into. Im assuming you may want to convert some of those 1080p movies which may incline you to look at which manufacturer gives better hardware video encoding/decoding/transcoding. i do remember seeing AMD/ATI offering a free video converter that utilizes a radeon card. that could in itself be a reason too get a 4890 over a 275
  13. Guest-16
    Guest-16 Guest
    Article will be posted next week :) It's the Sapphire 1GHz 4890. It's not an overclocked 285, no, but I dont think the difference is *that much* tbh.
    Actually in one of our recent articles we found a tri-core does better than higher clocked dual core in a couple of games.
  14. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    No SLI support with that motherboard, just incase you were wanting a board with SLI.
  15. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Agreed. Change to an Core i7 Motherboard supporting SLI.
    Fit a cheaper 275 or 260 and put the savings towards a second one later on.
    If your really after extreme gaming, look at these benchies. Notice where SLI 260's are compared to a 285. SLI 275s will be even higher...
    EDIT: My two cents...
    Coolermaster dominator 690 - Fine
    corsair tx-650w - Not enough conncetors for 2x 260/275. Get a Be Quiet! Dark Power Pro 750w
    asus p6t se - Get the Deluxe or Deluxe V2 or if you need the savings get a Gigabyte GA-EX58-UD3R which with a BIOS flash supports SLI
    intel core i7 920 (2.66ghz) skt 1366 box - Very Nice
    noctua nh-u12p se1366 - Perfectly Sufficient
    gskill kit 6gb ddr3 1600mhz pi (cl8) - Hope you have a 64Bit OS sorted.
    Seagate 500gb sata ii 16mb sp (7200.12) - Definitely Change for a TB model.*
    samsung dvd±r 22x sh-s223f preto bulk (sata) - Will Do the Job
    bfg gtx285 ocx 1gb ddr3 pci-e - Change as Above
    Hope that Helps :D
    * The Larger Space & Cache = better performance. HDD is slowest part of your system so it pays to get the best you can. :thumb:
