Scratch Build – In Progress 1 of 3 Project :: DIY Aluminum CNC (Finish Lastest update 04/09/2013)
Discussion in 'Project Logs' started by iD2, 11 Jul 2013.
  1. BeeP
    BeeP Minimodder
    17 Dec 2009
    I use a Haas vmc almost daily & I still wouldn't know where to begin making one.
    Fantastic work, I'm looking forward to some vids of it running.
  2. Fridge Gnome
    Fridge Gnome Blue Everywhere
    11 Dec 2012
    I'm so jealous right now.
  3. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    It's coming along nicely. Everything I see a CNC build I get so incredibly jealous. Then I start looking at my bank account.
    I could sell my car...
  4. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Crazy stuff man!! Looks amazing!!
  5. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you, I think i will finish assembly it soon but for electronic kits i'm still do nothing.
    Will more pictures update soon.
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    Working with X Axis base and table top then assembly rod rail and then assembly Y Axis and Z Axis.
    More pictures , iD2CNC.wordpress.com
    X Axis base and table top ::
  7. iD2
    iD2 Minimodder
    25 Mar 2012
  8. Cheapskate
    13 May 2007
    Wait. How will you put T-slot nuts in the table? It's blocked on both sides like this.
  9. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    You only need one kidney... :worried:
  10. iD2
    iD2 Minimodder
    25 Mar 2012
    It have 2 solution.
    - Use aluminum profile free nut
    - Extend aluminum profile slot to fit t-nut (about 10mm)
  11. Asouter
    Asouter --------
    18 Jan 2012
    You did say this was simple to make right ? maybe for you but WOW I really want one of these
  12. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    I really want one of these, I could take my modding to another level with a cnc. If I can sell my PC Im gonna buy my next project and a CNC for sure. It looks like a fun ass project to build as well.
  13. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    a cnc is not so easy to use, it involves more than simply designing, putting stuf on the table and pressing enter, it has like everything a learning curve. it is not an accident that for profeccional use u need a couple years training.
    i can say that designing and building my machine was the easiest part, the propper usage and maintanance is where the difficultie lies.
  14. iD2
    iD2 Minimodder
    25 Mar 2012
    Machine test assembly ::
    Test ::
  15. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Dam that looks sexy :p
  16. iD2
    iD2 Minimodder
    25 Mar 2012
    Let working with ball screw mounting plate for X Axis
  17. iD2
    iD2 Minimodder
    25 Mar 2012
    It not easy like you say but not much difficult. If you know what it important to learn and what an optional to learn then go to learn.
    For my first start DIY CNC machine i confuse everything but after i stop learn all of them and then make a check list to see what an important to learn and go to learn it for a bit just for know it what is it after that go to start design it or make it easy by buy some plan to learn it what the components it need , how they assembly together. So if you stuck for something that the one you need to learn about it.
    Or see my blog and then see each axis build , how to assembly them , how them assembly together. :D (but if it not be a good guide , really sorry)
    :D
    :D
  18. iD2
    iD2 Minimodder
    25 Mar 2012
    :D
  19. iD2
    iD2 Minimodder
    25 Mar 2012
    After did abrasive paper ::
  20. iD2
    iD2 Minimodder
    25 Mar 2012
