1 or 2 Screens
Discussion in 'Hardware' started by thehandsome1, 14 Jul 2008.
  1. thehandsome1
    thehandsome1 What is Windows?
    11 Jul 2008
    sonner or later i would have to get another or a new screen for my computer...i m a graphic designer and i need a big workspace or 2 screens...so i was jus wondering wut sohuld i do and wut type of screens are the best:read::rock:
  2. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I would suggest getting two monitors. That way you can move them around instead of having just one large monitor taking up a lot of space on your desk.
    As for what monitors you should consider buying, take a look at some of the reviews bit-tech has done reciently.
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    your most likely better off spending your money on a single high quality screen, as big as can get aswell. then use your old screen as a secondary.
    considering your in graphic design, colour recreation upon the screen is most important. your old screen can display toolbars.
  4. identikit
    identikit Minimodder
    5 Jun 2004
    Getting the best panel is useless if you can't calibrate it though. Seriously invest in a calibration tool.
  5. Burnout21
    9 Sep 2005
    that is also true.
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    are you going to get LCD or the old CRT monitor???
  7. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    What you should do is use 2 monitors, basically. All the advice above is quality and can be relied upon.
  8. thehandsome1
    11 Jul 2008
    well LCD because CRT monitors are old fashioned...n im probably right...everyone likes LCDs:rock:
  9. chrisb2e9
    18 Jun 2007
    I wish I still had my crt. it was damm good till it slowly started to get dark. sure it was big and heavy but the visual quality to me was better.
  10. ComputerKing
    8 Sep 2006
    I think one 30" DELL or APPLE will do the job more than perfect
    What your budget is ?
  11. The_Beast
    21 Apr 2007
    Like chrisb2e9 said the visual quality is better than an LCD
  12. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Personally, I'd be quite tempted by two identical monitors side by side... don't know why, but I get the feeling it would be the most convenient and practical set up, for any situation...
  13. rls669
    rls669 i can has dremel?
    15 Mar 2008
    When I was doing a lot of 3d modelling I found a 2nd monitor to be invaluable. Now that I hardly ever do anything productive on my pc, I'm selling my 2nd monitor and putting the money towards a hot new video card.
    And then in a few months, I'll almost certainly get annoyed by the lack of a 2nd monitor, and get another one :)
