1 U coolers!!!
Discussion in 'Hardware' started by Koolvin, 4 Oct 2001.
  1. Koolvin
    Koolvin The Modfather
    12 Mar 2001
  2. ChriX
    ChriX ^
    30 Aug 2001
    Does this have the holes that the Blorb has, cos I dont want to glue it to my precious card? :D
    -c
  3. Koolvin
    12 Mar 2001
    Have to Glue it!!!
  4. Guest-16
    Guest-16 Guest
    Oo wonder what it would look like on a GF3 Ti?? If it would be any good???
  5. ChriX
    ChriX ^
    30 Aug 2001
    ok, me admits that the blorb is crap, because it is either cooling very well, or is conducting heat like a piece of paper. On my GF2 PRO it only gets slightly warm even when running 3dMark2k1.
    Does anyone know how this new 1U cooler compares to the new Orange ORB also at The Overclocking Store?
    NOOOO!! No Gluing, cant have that on my poor card. :p (lol)
    -c :cool:
  6. Phil
    Phil New Member
    19 Jul 2001
    The fan on the orange orb spins faster and moves more air, it's just like the blorb really, but this copper heatsink will pull heat from the chip faster, it's 50x50mm remember, and the heat has les distance to travel.
    I'm still very sceptical about the design of the orbs, I personally cannot beleive that heat will actually be conducted up onto the radial fins. I'm sur the only reson the dragon orb works well is the largish copper heatsink at the bottom, I'm sure the blue fins do bu**er all.
  7. ChriX
    ChriX ^
    30 Aug 2001
    I may get me-self an orange orb, because they are in one piece aren't they? It should be good because the blorb failed because it was in two pieces and only soldered in 2 places.
    -c
  8. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    i got a h00ge skt7 heatsink on my graphics card :p no need for anything else ;)
  9. Guest-16
    Guest-16 Guest
    I must have the only blorb that works reasonably well. on my GF sdr it barely gets hot, but i didnt risk one on my northbridge and stuffed a Skt7 heatsink on it like spike.
    Id like to see if the Or'orb is any better then the Bl'orb.
  10. Phil
    Phil New Member
    19 Jul 2001
    nah, can't call it an Ororb, that sounds silly.....
    The 1U H/S that this thread is about has the advantage of being as good as the socket 7 hs/fans but it's lower profile so you don't waste another pci slot :)
  11. Jamie
    12 Mar 2001
    I would never stick the big one on an AMD CPU :eek:
  12. ChriX
    ChriX ^
    30 Aug 2001
    lol, yeah Ororbs here we come. I may order meself one of those soon, I want to try one...
    -c
