Windows 1 v 1 war game
Discussion in 'Gaming' started by numanoid, 16 Feb 2018.
  1. numanoid
    numanoid Well-Known Member
    26 Apr 2009
    Hi guys .it wont let me pick for windows , are there any war pc games that i can play a 1 on 1 online with a mate like the old moh games, one would pick a map and the other would join via ip address, thanks guys
  2. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    Changed it to Windows for you, not sure why it didn't let you.
  3. numanoid
    26 Apr 2009
    Thanks hex bud
  4. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    Will look into this
    Thanks.
  5. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Day of Defeat Source has the option to create a server, you can set the player numbers and lock down with a password if required. I know it’s been around for a while, but I still love playing it.
  6. numanoid
    26 Apr 2009
    Thanks matey ill look into it cheers
  7. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Not sure if you just want an FPS suggestion but check out Company of Heroes on Steam, great 2 player skirmishes to be had!
  8. numanoid
    26 Apr 2009
    Excellent ill check that game out bud, thanks very much
  9. fix-the-spade
    fix-the-spade Well-Known Member
    4 Jul 2011
    All of the Source engine games (Team Fortress 2, Day of Defeat, Counter Strike Global Offensive) will allow you to set up a 2 player server, or to run a normal sized server from your own PC with password protected access.
    You can make private game on Insurgency too, but it requires console commands and is quite long winded to set up.
  10. numanoid
    26 Apr 2009
    Thank you bud im looking into those games, thank you.
  11. true_gamer
    true_gamer Well-Known Member
    4 May 2009
    Sniper Elite V2 or 3 or 4. Can be setup for a 1v1 :)
    Back in the day, you couldn't beat playing Command & Conquer Red Alert Retaliation on the PS1 linked up with a friend, sat either ends of the table spending hrs building our massive bases, before going to war with each other. :)
