Graphics $100-$170 card
Discussion in 'Hardware' started by Jathm, 4 Jun 2005.
  1. Jathm
    Jathm What's a Dremel?
    15 Oct 2004
    Well i have kinda been out of the loop on graphics cards for a while and i was wondering what card i should get for about 100-170 dollars. Im running a 2500+ athlon with 768mb of ram. I know this isnt a great system but i was thinking i could get a 9800pro or something better for my system. Well any advice is apreciated.
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
  3. Jathm
    15 Oct 2004
  4. woodshop
    woodshop UnSeenly
    14 Oct 2003
    The X700 only comes in the PCI-E flavor not in AGP i do belive
  5. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    If you want ATI go with a 9800 pro. Look hard enough you can get one to fit your budget :)
  6. TMM
    TMM Modder
    12 Jan 2004
    The X700 is slower then the 6600GT in most respects. Go with the 6600 :thumb:
  7. Jathm
    15 Oct 2004
    alright thanks. Im gonna go pricewatching and scrounge me up a good card. thanks for all the help. Any recommendations on a good manufacturer ? I was thinking pny or msi ,but any thoughts would be helpful.
  8. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
  9. Froggy
    10 Jun 2003
  10. GigantoR
    21 Jul 2004
    Noooooo. I don't see the point of buying older hardware if the newer stuff you can afford? (lol, didn't mean to sound like yoda there)
  11. Froggy
    10 Jun 2003
    ok then...
    http://www.newegg.com/Product/Product.asp?Item=N82E16814102529
    few bucks over budget (skip lunch for a day or 2), but makes the damn 6600 look like crap. :)
  12. GigantoR
    21 Jul 2004
    Well, I was gonna come back and recommend the 6800 from Leadtek, but its out of stock, and I was about to order one :waah: :waah: :waah:
