Graphics $100 AGP card
Discussion in 'Hardware' started by The Savior, 7 May 2006.
  1. The Savior
    The Savior What's a Dremel?
    28 Sep 2002
  2. NoahFuLing
    NoahFuLing What's a Dremel?
    18 Jun 2005
  3. The Savior
    28 Sep 2002
    The reason I wasn't really considering that card was that it only has 128mb of RAM. Since WoW and HL2 aren't that graphically taxing would benefit more from the additional RAM than the higher clockrate (Comparing the 6800 Noah listed vs the 6600 I listed)
    [edit]
    http://www.newegg.com/Product/Product.asp?Item=N82E16814102665
    This looks good, but it looks like I might have to get an aftermarket cooler, since the reviews say it is loud.
  4. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    If you can stretch to the 6800 then you'll be getting a great card, that you may well be able to unlock to get some additional performance, or minimum overclock like a beast. If you can't then i'd say go for the X1600PRO.
    At that speed the card will not be limited by the amount of ram it has on it. The 6800 will absolutely murder the 6600 in performance ~twice the performance (i used to have a 6800LE which unlocked to 16x5 pipes and overclocked well too, and it was a beast even with "only" 128MB RAM).
    Also theres the 6600GT which is a decent step up from your old 9800pro
    http://www.newegg.com/Product/Product.asp?Item=N82E16814145098
  5. zinger
    zinger What's a Dremel?
    27 Jun 2004
  6. thestig198
    thestig198 Artificially Intelligent
    24 Jan 2004
    I'd get the X1600 Pro or the 6800, definately worth the little extra.
  7. zinger
    27 Jun 2004
    1600 Pro cards are worse than the 6600GT's. If it was me I'd get a used X800 off ebay or the local free ads.
  8. twistednet
    twistednet What's a Dremel?
    9 Dec 2005
    My 6600gt plays HL2 fine at 1280x768 (highest my monitor supports)
  9. BFGunrunner
    BFGunrunner What's a Dremel?
    13 Mar 2006
    LMAO now ive heard it all a video card dies in a lightning strom
    well yea try and get atleast a 6800 mabey a 6800 XT for $110 a very nice card.
  10. ToiletGamer
    ToiletGamer What's a Dremel?
    29 Mar 2006
    Like alot of others here have said go with the 6800. Very nice upgrade from your old card, you wont be dissapointed.
