Education 101 alternative uses for a Dremel
Discussion in 'General' started by manxminx, 12 May 2009.
  1. manxminx
    manxminx Opps, I broke my Dremel . . .
    9 May 2009
    1. ChiroDremel - Calluses are history! The grinding Wheel will soon make your feet feel better.
    2. Dremel & fork - No Steak knives? The 546 Rip/Cross-Cut Blade will make mince meat of that tough joint you bought for £1 at Netto.
    3. BeautyDremel - Fed up of the missus spending all your money down the beauty salon? Buy her a Dremel polishing kit. Smooth skin & shiny nails are only a dremel away.
  2. Veles
    Veles DUR HUR
    18 Nov 2005
    There are probably about 50 dental procedures you could do with it :p
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    4. sex toy - want to be power f***ed? get the sex toy attachment and get to it.
    5. cheesecake maker - makes a cheesecake fit for the relix.
  4. mrjimmyos
    mrjimmyos Ex-CPC member :/
    25 Apr 2009
    6. Attacks on lego people
    pimonserry likes this.
  5. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    7. Juice extractor. Whack on a router cutter, go for max power and show that fruit who’s ‘da boss.
  6. Guest-23315
    Guest-23315 Guest
    :thumb:
  7. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    8. Dew claw (dogs) trimming - I know someone who does that with their woofbags
  8. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    9. Who needs scouring pads? Use the sanding attachment to clean the crap off your kitchen pots!
  9. wolfticket
    19 Apr 2008
    10. Dremel your Dremel - Use a flex shaft with an engraving bit to personalise your Dremel.
  10. unknowngamer
    unknowngamer here
    3 Apr 2009
    tailor
    Surgeon
    I dropped a dremel (cheapo dremel clone tbh) on my leg, went through my pants and cut a chunk out of my leg. I can tell you it cuts through both very well (still got the scar)
  11. Major
    Major Guest
    11. Fouth Hole - Give your woman the 4th hole she's always wanted.
  12. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    12: Polishing up your iPod. Buff out those overuse scratches from the back of your pride and joy...
  13. Gooey_GUI
    Gooey_GUI Wanted: Red Shirts
    3 Dec 2002
    Slicing turkey on Thanksgiving
    Sharpen pencils
    :p
  14. Zoon
    12 Mar 2001
    Sorry, I had to...
  15. wolfticket
    19 Apr 2008
    I was worried someone might as soon as I posted it :rolleyes:
    :thumb:
  16. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    13. Use it in place of a can-opener. Real men power tool everything - even soup.
  17. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    14. Can't your tape drive rewind? Use your dremel for it. Its quick :)
  18. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
  19. Gooey_GUI
    3 Dec 2002
    16. Makes wearing safety glasses optional. :idea:
  20. liratheal
    20 Nov 2005
    rofl!
