#63 Re-attaching the exaust onto your car - life saver when you're 100 miles or so from home with no cash... #64 attaching your tools to your desk so no ****er steals them. #65 chewing them like a farmer chews grass. Not sure why people do this but they seem pretty adictive. Don't do cable-ties kids!
#73 using them to attach the rubber hydralic hose to a copper one #74 keeping your scuba gear together on the boat so that it dosent go off the back of the boat
79. holding your bedroom light to the ceiling 80. attaching a copper pipe to a microphone stand as a water rocket launcher 81. attaching surround sound speakers onto wall 82. poking through little holes in the ceiling then tying a coax cable to it and pulling it through so that i can finally get sky digital in my room 83. tying network cables to underside of desk 84. hanging a pentium 233 so that i can throw random things at it shouting "death to intel!!" 85. attaching cap of usb pen drive on to strap so i dont loose it 86. mobile repair (when used with gaffer tape) 87. making rounded ide cables 88. holding a "danger of death" sign to computer case 89. fixing multimeter cables 90. attaching wireless camera to RC car 91. attaching torch to above car to use in the dark 92. fixing scotland flag to wall
93. ghetto handle for making side panel removal easier 94. strapping usb extension to side of case (for those without front connectors) 95. holding up TV antenna 97. coat hangers 98. fixing molex plug 99. holding many cables together (useful for sound desks) 100. hanging el wire from case top 101. tying cd racks together w00t!!!!!!!!111oneone222two finished!
A New #25 Possibly Strap A Couple Thousand Firecrackers Together Then To Yourself, I Hear They're Economical Status Is Getting Worse Over There, Then Try To Become A Suicide Bomber?
now that would be interesting to see on the front of the web site ... BIT-TECH exclusive!!! 101 uses for cable ties
The "key chain" thing was mentioned twice so i add ##Tying together cable bundles for storage or easier transport.
i'm amazed at you lot.... after the number of times peoples paintwork/mods have been ruined/contaminated by the untimely intervention of cats..... 102: attatching cat to demagnatizing dog to prevent modding interference search: and you will get it) (and before you all shout loudly, think of it as a backup, just incase theirs a duplicate)
We need picture examples for everything. Sad thing is I only use zipties for what they're meant for...cable management. And never inside the case, I only use sleeving for that. I just carefully route my cables... using those tiedown things is annoying if you ever move anything around.
Ok, typically used for if you wanna get technical. And I'm talking by more than modders. There's a reason they're often called cable ties though. Note the thread title
Pics are a must for this! obviously we dont want anyone killing or harming anything of course *gets out CAM and hunts for the dive gear and the keys to my car*
