Networks 108mbps wireless network..
Discussion in 'Hardware' started by jake^the^cake, 2 Mar 2004.
  1. jake^the^cake
    jake^the^cake What's a Dremel?
    1 Oct 2002
    The old computer that has worked as a router just died, and my dad said he wanted wireless network, 108mbps.
    I know a bit about wireless networking, but not alot, and really like nothing about manufactureres. So give me your 2 cents, what do you think about it?
    I've looked at a D-Link router (DI-624 http://www.dlink.com/products/?pid=6 ) and pci-cards (DWL-G520 http://www.dlink.com/products/?model=DWL-G520 ).
    Anyone tried em?
    Also, the router only got 4 ports, whats the best/cheapest way to get more ports? just getting a access point?
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    Dlink makes some of the best stuff imo but youll have somebody come under this and say its crap...I use the stuff daily at work and I like it the best but Netgear would be a close one as well, which they also offer 108 stuff...
    If you want more than 4 wired computers to the router youll just need a switch with an uplink port. If your just looking to add more wireless pcs the router can support +25 computers wirelessly. (The Dlink rep told me 235, but they also say it will reach +1000 feet as well)
  3. p3n
    p3n What's a Dremel?
    31 Jan 2002
    It will with a 1000 £ aerial :)
  4. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    I have a D-Link DI-624 + 2x DWL-G520s and a DWL-G650, I get about 15mbps throughput across the network (need better antenna).
