11/25 ------ L I Q U I D - M E T A L ------
Discussion in 'Project Logs' started by Mr.B, 26 Dec 2004.
  1. ModKid
    ModKid What's a Dremel?
    5 Jul 2002
    im guessing you like bondo alot :p
  2. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Very nice bog work. You've got some great ideas here and excellent exocution as well to back them up :thumb:
    I love the "interference" design of the dual blowhole and the freeform work. How did you drill the holes? Was it with a drill press or just from the back. I find attepmting to drill into a chamfer by hand a futile effort at best.
  3. Pistol
    Pistol Guest
    [off topic] How does one go about getting a job in a shop like that? I'd love to pick up some of those skills DÈF¥âÑt¸.·´¯`¤. By the way, think you could post a guide for bondoing over on this site, too? [/off topic]
    Some great work man, I'm not sure if I like the front panel or not...maybe when its done, but it's got a big pieced together look to it.
  4. Mr.B
    Mr.B What's a Dremel?
    26 Dec 2004
    Ya i know what your saying about it looking pieced togehter. ALlot of that is because its got tape around it still and the bay mod is primered in that pic, and theres no fan behind the intake. Trust me, itll look much better once its all painted and what not.
    Thanx for all the compliments everyone!!! :D :thumb:
    Bad News: Dremmel Broke
    Good News: First Side panel will be done very soon.
    Good News: Get a New xpr dremmel. :D
    Until Next.
    Bryan-
  5. Pistol
    Pistol Guest
    On that note about the front, are you going to blend the drive bay devices into one seamless piece? That would look best, with the rest of the case looking as it does.
  6. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    I love this whatever-it-is-thinga-majigie! Very clean and professional cut.
    Did you just use scrap metal or is it an OEM item?
  7. Mr.B
    26 Dec 2004
    Pistol >> Im not too sure what im going to do with the drives. Im messing around with some LED stuff at the moment, maybe bondo the front of the drives smooth or something, thats the only part of this project thats kinda up in the air at the moment.
    Phoeneous >> That is the stock top panel of the case. I just outline the area in which i wanted the bondo to be, then i cut the tape away with an exacto razor. :)
    Thanx guys any more questions ill be happy to answer. :D
    :rock: Mr.B :rock:
  8. mondriaan
    mondriaan What's a Dremel?
    20 Aug 2004
  9. 3t3rn@l
    3t3rn@l What's a Dremel?
    29 Nov 2003
    great work there, i love the bondo work its so detailed, cant wait to see the end result ill be watching this one :thumb: :hip:
  10. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Keep up the good work.
  11. huren
    huren What's a Dremel?
    14 Aug 2004
    /me demands an update !1!!!
    [offtopic]good too see bog[/offtopic]
  12. Mr.B
    26 Dec 2004
    [Bit up an Update 2/08]
    Side panel work is in process. Should be done with the bondo by friday, where ill post more pics. But heres what were looking at right now. :D
    WIth the cuts made
  13. ou7blaze
    ou7blaze sensational.
    5 May 2003
    You've got some good stuff going on , keep up the good work mate! :rock:
  14. mondriaan
    20 Aug 2004
    WE WANT UPDATES??
  15. Mr.B
    26 Dec 2004
    I know Im sorry. This double major thing is kicking me in the nuts right now in regards to time, especially with finals week coming up. Update commin monday or sunday. Next quarter i have no class on mondays or fridays so 4 day weekends here i come, some serious modding is gonna get done :D :rock:
    -Bryan-
  16. Mr.B
    26 Dec 2004
    | UPDATE 3/08 |
    Allright, well I got a little more work done, I drew this little flame lick for the top panel. Im going to be cutting that same size lick out of Plexi, then some polished aluminum lick (a little smaller) will be placed on top of the plexi. (the plexi will also be lit by Blue Leds.
    Pic
    Ive made a bondo fan holder for the outside of the case side panel. I thought merely mounting the fans on the outiside of the case would be very tacky, so i got the bondo out and came up with this beast :D Sanind took forever.
    Pics
    Another update to come soon!
  17. KidModder
    KidModder What's a Dremel?
    22 Dec 2004
    [Off topic] How old are you ModKid?[/]Nice case. You must realy luv bondo.
  18. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Nice fan holder. I'm happy you update this again. It's a good work.
  19. mondriaan
    20 Aug 2004
    looking good.
    Just wondering; Why did you put the fan outside of the case side panel??
    You've put the rest all inside?? Would't it look nicer on the inside of the panel like the rest??
  20. Machine
    Machine What's a Dremel?
    27 May 2004
    this mod realy diseves top rating :rock:
