Ya, sorry forgot to explain that, a second Bix dual 120 Radiator is goin behind those fans, if i put em inside, there would not be enough space inside the case.
For all you Watercooling gurus out there, i pose a question that ive been thinking about lately. If Im running a 1/2" ID system with 3 blocks, 4 reserviors, 2 duals 120 and 1 single 120 radiators, how many pumps should i use. Should I use 2 pumps and make 2 seperate loops, or just make one biiiiiiiiiig loop. Thanx.
i would put the vga + 120/2 rad in one loop and cpu/chipset in another loop with only a 120/2 rad, doubt another 120/1 rad would make much difference, it'll just slow you flow rate, same with the 4 res, its just overkill, just have one for each loop
UPDATE 3/17 ALrrighty then. I have some more progress today. Got the cuts of the plexi down, now they need a little bit of sanding, but heres the general idea of how its going to look, there will be some more bondo work done. Then dont forget the modders mesh and leds . ANyhow, heres the pics. w00T!! Tons of updates to come!
no res's are needed with that many rads Alot of people run 2X 6800ultras + fx-55's highly oc'd with a 120.3 rad, so your 3x rads is abit overkill. Erm im not sure if you should have 1 big loop, not sure...
Ooooohhh.. this looks very nice indeed!!! Makes me feel all warm and mushy inside... Keep them updates coming!!
Diggin the flames bro! Nice work over all, but I like (for obvious reasons) how you are implementing a flame effect!
Thanx tech daddy, ya i love the flames, flames So glad i got the idea cuz that top was lackin something.
Im gonna wrap the plexi flame and circles in modders mesh with blue leds lighting the plexi so the blue light will shine through the mesh, im also putting a polished aluminum flame, the same shape but smaller on top of the mesh. Then i will be painting the bondoed part blue, the same paint that i used on the intake front bezel.
