Case Mod - In Progress 12 Angry Men 900 D case
Discussion in 'Project Logs' started by arg-ist, 14 Jan 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Playing with the new case 900D
    My new case is 900 D
    I used:
    Case Corsair 900 d
    MB Asus Maximus 6 Formula
    CPU 4770K
    CPU WB Koolance CPU-380I Water Block
    Video MSI GTX 680 Lightning
    RAM G Skill Trident 2400 MHz 2X8 GB
    SSD OCZ Vortex4 512 GB
    Sound C. SB Recon 3D Fatality Pro
    PSU Seasonic 850 80+Gold
    Pump Swiftech 655 + Bitspower TOP + Bitspower Mod kit
    Fittings XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting - Chrome Finish
    Tubing PrimoFlex Advanced LRT Tubing - 1/2in. ID X 3/4in. OD - Crystal Clear
    Fluid PrimoChill Liquid Utopia Fluid Dye Pack - Blood Red
    Keyboard Razer Blackwidow Ultimate 2012
    Mouse Razer Mamba
    First, we used Asus Cross Chill cooler for watercooling
    We provide the heat of liquid to stay stable at degree that we want by relating the inline sensor with aerocool fan controler alarm.
    Avaible MSI videocard, is used with air cooling for now.(a Evga 780 is coming soon)
    RGB led is used to find the light and colour that is wanted in the case.
    The photos are trial photos which are taken for this purpose.
    although CORSAIR 900D is a big case, but some mistakes appear.
    That there is no middle plate at the case.
    When 480th radiator is installed to the front of sub-part, there is 50mm space left except 60mm radiator+25mm fan.(photographed)
    It is impossible to mount a radiator and fan together in this place.
    Even if a thin radiator is used, there is no place left to work and joining between radiators.
    There is no free place for pumps , you must remove HDD cages.
    I think 900D was produced as a big case at first, later it has been minimized.
    Don t think ,900 D is a big Case for watercooling…It is a MINI – BIG CASE only…
    I hope Corsair 900D V1 is coming soon…
    We are planning to change Asus MB Waterblock with an EK
    And make a middle plate by next threads.
    And a new Evga 780
    http://www.youtube.com/watch?v=2RqF4IdZggc
    OTHER WORKLOGS
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
  2. arg-ist
    arg-ist Minimodder
    21 Dec 2013
