Case Mod - In Progress 12 Angry Men SPIDER WEB CASE (900 D) FINAL
Discussion in 'Project Logs' started by arg-ist, 17 Jul 2015.
  1. arg-ist
    arg-ist Member
    21 Dec 2013
    Although 900 D is a big case , but subdivision too cramped.
    U1
    One small problem of the case is mounting of the PSU and and work on them.
    U2
    Only the bottompart of the Rad mounting plate (at back side)is portable. upper part is fixed.can not be romoved.
    U4
    To be a little more comfortable in the PSU mounting and mounting of PSU connectors ,
    I made a mounting plate to install PSU. As I was accustomed from SilverStone TJ 07. Cosmos II
    U7
    U13- U14
    I cut the mounting location of PSU.
    U6
    Made a mounting plate from 2mm thick alu.
    U8
    So that, I can mount PSU without tilting and wriggling…
    U15
    U9
    And ı cann take out the PSU without disassembling back rad.
    PSU with mounting plate
    U10
    Pushing the PSU in the case ,backplate with PSU , mounted to the case with four self-tapping screws.
    U11
    I'm pulling out the PSU and can mount easily PSU connectors.
    With adding a frame from 10x15 mm box profile to the backplate , can I mount , an additional 360mm rad to the bottom part of the case ,if it is necessary.
    Mounting plate sent to powder coating.
  2. itrush07
    itrush07 Member
    28 Nov 2007
    This is brilliant, very well done...
  3. arg-ist
    arg-ist Member
    21 Dec 2013
    Thank you itrush07
  4. arg-ist
    arg-ist Member
    21 Dec 2013
    I am also curious as you are for the result. I want to see midplate with color.
    I could not wait .
    I photographed , before filling colored liquid , with clear liquid and RGB led light.
    1 red led
    2 green led
    3 blue led
    4 yellow led
    5 white led
    6 light blue led
    7 orange led
    And then with selected fluid MAYHEM X1 Blood red .
    .8mayhemX1
    a short break
    2 Weeks late summer holiday at Fethiye /TURKEY , to watercool my self
  5. arg-ist
    arg-ist Member
    21 Dec 2013
    Holiday is over, continue to work
    Worklog of this week.( It's hard work after the holiday…)
    Step by step final assembly.
    Empty case
    R1
    First montage of the pipe from pomp to 480 rad.
    R2
    From MB block to monsta 480
    R3
    Montage of EVGA 980 Classified Hydrocopper
    İn and out pipes of Evga 980
    R4
    Montage of reservoir without montage bracket like a tower.
    R5
    Montage of pomp on 3 feet, without montage bracket.
    R6
    R7
    R8
    R8a
    And at last self made SPIDER WEB GRIL
    With 5K Potansiometer as dimmer.
    R9
    R10
    R11
    Spider web grill backlighted with led strip and with a dimmer.
    R12
    Case illuminated with led without fluid, to see th effect and to predict the result.
    R13
    R14
  6. bakan
    bakan New Member
    19 Sep 2015
    Nice.. Great Work ...arg-ist... as wlways.
  7. arg-ist
    arg-ist Member
    21 Dec 2013
    Because I have changed my house , ı could not add final photos.Sorry.
    Some final photos
    Although I think the pump to work properly upsidedown.
    but I changed pumps position not to risk the pump
    Thanks for warning TheL4mka Multimodder.
    1 [​IMG]
    2 [​IMG]
    3 [​IMG]
    4 [​IMG]
    5 [​IMG]
    6 [​IMG]
    7 [​IMG]
    8 [​IMG]
    9 [​IMG]
    10 [​IMG]
    11 [​IMG]
    12 [​IMG]
    13 [​IMG]
    14 [​IMG]
    15 [​IMG]
    16 [​IMG]
    17 [​IMG]
    19 [​IMG]
    20 [​IMG]
    21 [​IMG]
    22 [​IMG]
    23 [​IMG]
    24 [​IMG]
    25 [​IMG]
    26 [​IMG]
  8. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    I actually don't like red, or scary spiders, but that bottom with all the water canals is AWESOME!
    Unbelievable cool, super awesome work man!
