120Gb Western Digital 1200JB
Discussion in 'Hardware' started by Piratetaco, 17 Jul 2004.
  1. mushky
    mushky gimme snails
    24 Mar 2003
    the WD seems faster to me. maybe i'm imagining it cos I'm a bit sentimental and my WD has done me proud but it just seems a bit nippier around windows XP, opening explorer windows + the like.
  2. Austin
    Austin Minimodder
    16 Jul 2004
    :hip: Cool. I've got 4 HDs split across 2 PCs here at home ... Maxtor 7200-2 80GB, Seagate 7200-2 120GB, Hitachi 7200-2 160GB and Maxtor SATA 7200-8 120GB. Outside of benchmarks and timing I don't notice any remotely tangible difference between them. I guess as is often the case with PC components, in reality there's very little between them all so we come down to very picky tiny differences. If I had the choice between BrandA (top HD manu) with 1 year warranty and 'lesser' brand with a 3 year warranty for MORE money I'd take the 3 year one every time ... unless it's overly noisy (v.important to me) or a Hitachi (2/3 dead in 9 months is not a good sign).
  3. phuzz
    phuzz This is a title
    28 May 2004
    For what it's worth, I know a medium sized comp manufacturer in the uk that uses a pretty even mix of WD and Maxtors, although, now I think about it, that just means they're cheap and will last at least a year. Personally, I've got a Hitachi 80Gb SATA, and it runs about the same speed (ie only a benchmark will notice a difference) and a lot quieter than my maxtors.
    I'd agree with Austin tho and say go for who ever gives you the longest warrenty.
    After all, I'm sure you can find 10 people on these forums who will swear blind that (eg) WD is the best and most reliable etc. and another 10 who will slag em off. In the end, some hard drives are gonna be dud's, and some are going to be troopers, the only way to get ahead is have a good warrenty,
    just my opinion though, natch
  4. mushky
    mushky gimme snails
    24 Mar 2003
    a good warranty is certainly one gooed reason.
  5. liuh
    liuh What's a Dremel?
    10 Apr 2004
    I've got a 120gb 8mb cache, love it, but i also have the maxtor 120gb 8mb also...
    i haven't had problems with either.
    my friend uses all WD drives (3 of them) and no problems. I have 2 other WD drives (no problems) and i just ordered another one. (80gb 8mb)
    So really unless you are really unlucky...then you will have no problems :)
  6. batsman
    batsman the quiet one
    14 Nov 2001
    i've got two of those bad boys, one gets abused quite as its used as a scratch file for any ripping / video editing and the other is for os.
    I can't fault the drives they are fast and have had no problems with them (touch wood). The only complain I have is that 120 isn't big enough anymore :waah:
    but no would deffinatly recomend them :thumb:
  7. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    batsman do you mean the WD or maxtor drive?
  8. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    WD 80JB here no problems fantastic drive. Murdoc has the 120GB version again no problems.
    http://storagereview.com/articles/200201/20020124WD1200JB_1.html
    ^^^ review
    thats the conclustion, an old drive thou so there may be better,
  9. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Hard drives make a lot of noise? i cant hear them over my case fans.
  10. Austin
    Austin Minimodder
    16 Jul 2004
    ;) Your case is designed to be pretty rather quiet. 7x80mm fans, yikes!
  11. Froggy
    10 Jun 2003
    oh yea i switched 4 case fans out for vantech tornados. my system runs at 33C under full load. Also does about 25C idle. My thermal probes say 23C is my case temp so i guess im doing good.
  12. Firehed
    15 Feb 2004
    It's what came in a dell system that I bought some time ago. Indeed, a free upgrade from 30GB IIRC :) It's currently in my brother's computer and not causing any problems. I can't hear it at all either.
    Of course you won't hear hard drives over tornados. But I can't hear my dual raptor + 80gb Seagate SATA setup over my SilenX fans and PSU, except not very noticibly during write operations.
  13. Dimazz
    Dimazz What's a Dremel?
    8 Feb 2004
    Rite, just last page I was reccomending WD's.....My 80 died today :(
    I RMA'ed it, should be coming bak soon.
    But I still would reccomend WD's, good drives, have one thats 4 years old, not a hiccup...
  14. Piratetaco
    15 Apr 2004
    well i got the WD1200JB today.seems good.WD even gave me a program for cloning my old drive.thanks for everyone's help and suggestions.
    :thumb:
  15. TMM
    TMM Modder
    12 Jan 2004
    rofl, 4 tornados? :eeek: what do the neighbours say? :D
  16. Austin
    Austin Minimodder
    16 Jul 2004
    ;) While on the topic of HDs it's well worth noting that Seagate offer a 5 year warranty on ALL their HDs. Almost all other companies only give 1 year with the odd exception (ie top-end) which is 3 year. Seagate are well known for reliable HDs that are quiet and cool running. If you're buying I'd definitely suggest Seagate, in fact I wouldn't consider touching anythig else at the mo.
  17. Goreblast
    Goreblast What's a Dremel?
    6 Apr 2004
    Ive got 7 of the WD1200 8mb drives here and they are excellent - couldnt fault them.
    Seagate - wouldnt touch way too many problems over the years and besides they are made in Londonderry :worried:
