Displays 120Hz display for HD3D and 3D Vision??
Discussion in 'Hardware' started by wsmccusker, 13 Mar 2012.
  1. wsmccusker
    wsmccusker What's a Dremel?
    4 Sep 2011
    If I had a 120Hz display which was compatible with AMD HD3D and came with its own glasses,
    could I hook it up to an Nvidia gfx card and use the 3D Vision RF station and the Nvidia glasses to use 3d???
  2. Xunsu
    Xunsu What's a Dremel?
    24 Apr 2011
    IF you managed to find a 120Hz screen that has its own set of glasses, I would persome so yes, as long as its Nvidia 3D vision certified( stating they tested said monitor)
    If I was you I would try it out particularly the Nvidia one cos its very expensive, very annoying if you find you can't bare it.
  3. feathers
    feathers Minimodder
    11 Apr 2009
    3d vision 2 infra red transmitter box has a connector to sync with a TV. There is a list of compatible HDTV on nvidia website but when I checked some of the so-called TV codes I was getting google hits to projector bulbs!
    In any case u need to register and post on Nvidia forum in the 3d vision section. Someone should be able to advise you.
