Modding 120mm fan size.
Discussion in 'Modding' started by Visualaid, 22 Feb 2004.
  1. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    Hi guys.
    I've got some ideas for a case knocking around but i have no clue how big the circular hole but on a 120mm fan is and i really need to know. I got some templates of kong's site but cannot print them to size acuratlly because i have no clue with estimation. Has anyone got a good way of seeing how big the circle bit of a 120mm fan is?.
    Thanks in advance.
    sorry if the above doesnt make sense.
  2. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    non surprisingly, about 115mm. It might vary a little from fan to fan though.
  3. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    i remember reading somewhere that a cd is almost exactly the same size.
  4. Hallq16
    Hallq16 What's a Dremel?
    30 Aug 2003
    yep, true
  5. Mixx
    Mixx What's a Dremel?
    19 Oct 2003
    i forget which site but they have fan templates you can download and cut out to help you. i printed off some and if i find them ill let you know
    EDIT i found them, its www.moddin.net
  6. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    I've used Moddin's 80mm, and found it to work nicely.
  7. tk421
    tk421 Idiot.
    15 Jan 2002
    a 114mm holesaw is good for a bare edge, with trim, use a 120.
