Modding 120mm UV
Discussion in 'Modding' started by Zoomer, 15 Oct 2003.
  1. Zoomer
    Zoomer What's a Dremel?
    30 Jan 2003
    does any one know where i can get a 120mm UV red or orange, but if not any colour fan.
    I need it UV not LED as i'm taking the outer section off it.
  2. chadwick
    chadwick What's a Dremel?
    2 Oct 2003
    jab-tech.com do em
  3. Zoomer
    30 Jan 2003
    A UK supplier would be better but i might have to use them if i cant find any.
    thanks chadwick
  4. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    ive had a look around and all i can see r 120mm alu fans, and 120mm clear fans. though i did spot a few 120mm coloured fans here.
    edit/ how about using a LED fan but placing the leds around it after you've removed the outer frame.
  5. Zoomer
    30 Jan 2003
    I supose its possible but trying to place LEDs in thick Alu might be a bit more then I can chew.
    thanks for looking though.
  6. T.Donald
    T.Donald What's a Dremel?
    16 Sep 2003
    I'd avoid the uv fans from over-clock, I bought one and it turned out be a plain 120mm YS-tech that had been spray painted with that paint for RC cars.
    It was all proplery done though, no smears/thin spots but I still went and bought a proper UV fan from xoxide.com and very nice it is too :D .
