Modding 120mm x 15mm thick fans?
Discussion in 'Modding' started by Guest-16, 1 May 2006.
  1. haste
    haste What's a Dremel?
    19 Apr 2006
  2. Silver Spoon
    Silver Spoon What's a Dremel?
    12 May 2006
    It's probably a terrible idea but could you possibly take a file to a fan to get it to 15mm? Sorry if this is a stupid iudea, i'm a complete noob to this modding stuff
  3. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    This would maybe work for a few mms, but you will see the motor of the fan will get into the way, plus the fan blades are precisely designed so the airflow will probably lower drastically and the noise increase, however you could remove the outer body and leave one side to screw it on and remove all plastic around the blades and stick the fan throung the blowhole outside if this is what you want you want to use it for.
  4. sd619
    sd619 What's a Dremel?
    17 May 2006
    I think Thermaltake might make some thin fans. I posted a link to their site, but I think I'll do a little more research for you to find them.
    EDIT:
    I was wrong. This page shows a fan that is 13mm, but clicking on the link shows this page 2 that says the fan is 130mm X 130mm X 25mm.
