Electronics 120v pump power
Discussion in 'Modding' started by Haddy, 27 Feb 2002.
  1. Haddy
    Haddy World Domination
    22 Jan 2002
    how would i go about wireing up a 120v U.S. standard plug so that i can run my pump inside my case without having to put the cord threw the case.......i know kinda hard to understand but maybe my cheap attempt at a model will confu...i mean make u understand a lil better........
    @@case
    ====[]====power cord from pump
    ||@need to know how to wire this plug
    power from wall
  2. corvette
    corvette What's a Dremel?
    27 Nov 2001
    run the power cable into the power supply then hook the wires up to the main in put that should work but and i say but make sure u hook the right wires up or u will kill ur pump power supply and every thing else
  3. linear
    linear Minimodder
    5 Oct 2001
    Whatever you do, put a fuse in the 120V line. Make the amp rating an amp or so higher than the pump's current rating.
    Safety first.
