127 degree system
Discussion in 'Hardware' started by TheoGeo, 29 Jul 2003.
  1. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    ok, all the system temp monitoring programs i can find including the one suplied by my mobo company (MSI Alert 4) say my system is running at 127 degrees.... shouldnt my pc be dead right now? i was wondering if im just being dumb and u have to configure it somewhere or summot
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Well, 127°F = 47.2...°C, so my guess is that the program natively displays in Farenheit, rather than what most modders use, Celcius.
  3. maki43
    maki43 I can touch my toes 1,2,3
    8 Nov 2002
    What motherboard are you using? I built a computer for my friend using an Asus A7N8X and one of the probes said a temperature was 125c. Obviously this was wrong or else i would doubt the system would boot :D
  4. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    A P4 can apparently run at that temperature (I've seen a video somewhere of a p4 that boots windows right up to 130c and then shuts off). I'd check your cooling and see if it makes any difference.
  5. Gandi69
    Gandi69 Like to get busy wit fizzy..
    17 Jul 2001
    Just check that the software is configured for the correct sensors and probes in your setup, as this happened to me (in MBM software) and I managed to get a readout of 117ºC :eyebrow: , however once set to the correct probe/sensor I got a 32ºC temp readout.
  6. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    It was probably right. ITs an A7n8x. A piece of junk destined to fry your CPU
  7. TheoGeo
    10 Jun 2003
    its an MSI K7N2 DELTA-ILSR and it is set to display in celcius, ive also used MBM 5 which says the same thing, i tried MBM 5 on all available sensors and it either came up with 0 or 127
  8. wda97c
    wda97c What's a Dremel?
    25 Jul 2003
    Update your MSI Mobo bios. My MSI bios showed dodgy temps till I updated it and that sorted it out #(as well as fixing some memory timmings)
  9. TheoGeo
    10 Jun 2003
    sounds good to me, ill try it wen i have time to sort it out, should be getting a load of new hardware soon to go with my new mobo & processor including a case, i was thinking of getting a coolermaster 710 but not sure if i should get one thats fully alu
  10. xen0morph
    30 Jun 2002
    CM-710 is a good case. Get one, you won't regret it :)
