Overclocking 12gb RAM issue
Discussion in 'Hardware' started by barndoor101, 3 Sep 2011.
  1. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    Hi all, its been a long time!
    I just upgraded from 6gb to 12gb RAM in my main machine (in sig), the kit i bought was the Crucial 3x4gb DDR3 1600mhz (1.5v).
    First i try a straight swap, but the machine doesnt boot at all.
    So i try reducing the BCLK - turns out it will boot at 199, but not 200 (at which it was rock solid before). Also LinX runs into errors at this setting.
    I always thought that it was only the number of banks filled that would cause issues, not the total amount of RAM (which is all detected fine by POST btw).
    Anyone else had issues going from 3x2gb to 3x4gb?
  2. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    hello,
    My mate had the same problem, he has the same set-up as you, he had to reduce overclock to get 12gb of ram to run. The 12 gig would not o/c the same as 6gig did .I do not know the reason for this.
  3. Big Elf
    23 Apr 2009
    You may need to increase the QPI/VTT voltage a notch or 2, or adjust the timings. It's also worth resetting the BIOS if you haven't already done so.
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I changed from 6gb OCZ gold 3x2gb to my 12gb patriot set. Didn't even have to tweak a thing. Plug in and boot up at same bclk frequency which is also 200.
  5. barndoor101
    25 Oct 2009
    think iv sorted it - for some reason the RAM was setting itself to CL7 which is weird. It worked at 1200mhz as youd expect. so i loosened the timings to be CL10 (which is what the website says, although the packaging says CL9) and its running. doing a LinX test now, but all looks fine. i also put an extra 0.04v through the RAM just in case (so its at 1.54v not 1.5v).
  6. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    well that was helpful
    and I'd say now you've set it to CL10, run the test of LinuX, if it comes back ok then I'd probably drop the voltage back down to 1.5v and run the test again obviously :)
