$1300 for gaming comp-need help
Discussion in 'Hardware' started by pillow, 17 Aug 2004.
  1. pillow
    pillow What's a Dremel?
    16 Aug 2004
    i got 1300 to make a gamign comp. i want an x800 pro, 1 gig of ram, an amd 64, 120 gig of hd, and a nice case, any suggestions on wat to get cuz im not very smart :waah: (like wat mobo, wat ram, .....). i allready have a monitor, mouse and keyboard. please help.
    pillow
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Feedback?
    Moving...
  3. pillow
    16 Aug 2004
    my fault, but can ne one help me?
  4. zero002021
    zero002021 What's a Dremel?
    13 Aug 2004
    Sure thing.
    Processor: http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-483&depa=1
    Motherboard: http://www.newegg.com/app/ViewProductDesc.asp?description=13-128-241&depa=1
    Memory: http://www.newegg.com/app/ViewProductDesc.asp?description=20-141-423&depa=1
    Hard Drive: http://www.newegg.com/app/ViewProductDesc.asp?description=22-148-017&depa=1
    Then find a case you think looks good (try stuff by Antec, Cool Master, etc.).
    May need to buy a power supply if they dont come with one. Antec and Thermaltake make good ones.
    Last but not least, find a video card. Just read the reader reviews and you'll get an idea for which is the best for you buck.
  5. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
  6. pillow
    16 Aug 2004
  7. lunix_user
    lunix_user What's a Dremel?
    31 May 2004
    that case is incredibly overpriced.
    incredibly.
    my only input. :hehe:
  8. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    for that much id look at an Lian Li/ante. Too much of a thermaltake wanna be for me tbh
  9. Techno_Addict_2k4
    Techno_Addict_2k4 What's a Dremel?
    27 Aug 2004
    Try the website
    www.it-rite.com
    :rock: :thumb: :rock: :thumb: :rock: :thumb: :rock: :thumb: :rock:
    They Have
    • Cheap stuff you might think it would be stolen
    • The only problem it is in Australia
