Motherboards 1366 duel motherboard
Discussion in 'Hardware' started by johnim40, 13 Jan 2017.
  1. johnim40
    johnim40 Minimodder
    23 Apr 2009
    Hi all
    I have a 1366 motherboard at the moment with a x5650
    but looking on around i could get a duel cpu motherboard for £80 with 2 e5540s in
    i was thinking of swapping out the cpus for 2 x x5650 cpus and using that instead
    the motherboard is a
    INTEL S5500BC SOCKET LGA1366 DDR3 SERVER MOTHERBOARD
    https://ark.intel.com/products/36601/Intel-Server-Board-S5500BC
    so would this work with a standard atx power supply eg a corsair cx750 and standard ddr3 ram
    and a corsair 750d case
    i want to use as a game server eg ark survival evolved
    or would you have any suggestions
    Thankyou for your help John
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    CPU's are on the "list" on intel page, so they'd be OK.
    DDR3 ECC RAM - So not the normal desktop stuff.
    This thread suggests the bpard might fit in the 750d - http://forum.corsair.com/v3/showthread.php?t=122924 - its a 13" by 10.5" board - but the last post say Corsair don't guarantee it'll fit..
    PSU - no idea sorry.
  3. Hawkest_83
    Hawkest_83 What's a Dremel?
    8 Jan 2016
  4. Hawkest_83
    8 Jan 2016
    750w should be more than enough power and that CX 750 supports the correct EPS12V 8pin connector.
    However, it only has 8x PCIe headers and the 2nd CPU socket will restrict the use of large gfx card plugged directly into the board.
    hope this helps
  5. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I dont see any PCI-E x16 slots on that board. You might need to mod the 8x slots to fit a GPU.
  6. phuzz
    phuzz This is a title
    28 May 2004
    If it's a server it doesn't need a GPU.
    (And it's dual when you're talking about two things, "duel" means a fight between two people)
  7. johnim40
    johnim40 Minimodder
    23 Apr 2009
    Thanks for that guys i only need a display so big gpu needed
    lol i knew i spelt it wrong :)
    I found the manual too which says i need 3.5a on the 5vsb to even power it and only the high end psus have that
  8. Hawkest_83
    8 Jan 2016
    yeah a big GPU will need to be mounted elsewhere there isn't the room to plug it direct onto that motherboard.
    could an external control like an Arduino with a relay linked separately solve your problem with the 3.5 amps?
