Windows 14 player CS SERVER FOR TUESDAY 13th NOV. 7:15-12ish
Discussion in 'Gaming' started by Guest-16, 12 Nov 2001.
  1. Guest-16
    Guest-16 Guest
    IP: 192.150.183.19:27015
    icq: 81545566
    msn: bindi_badgi@hotmail.com
    I'll be setting up n testing from 7-7:15 so if you join, i may have to fiddle with settings etcetc.
    In the unlikely event of a puter crash - plz wait 5 mins and try to reconnect.
    Will take requests of maps, no custom maps this week though.
    FF off, 20-30min map time, ummm.... low grav if we get bored.
    My Name: "[Admin] Kebab or Shag?"
  2. Guest-16
    Guest-16 Guest
    Ooops forgot:
    PASSWORD is: mod
  3. Fatboy
    Fatboy Bored
    8 Oct 2001
    Do i use gamespy to get into the server cos i aint used GS before
  4. Guest-16
    Guest-16 Guest
    Na i use CS only.
    Umm something up with setting the pass?!?! i just try it earlier and it kept saying unable to set password or something? it *may* take a little while to set up tomorrow if it decides to be a bugger.
  5. acron^
    acron^ ePeen++;
    15 Oct 2001
    Bugger!
    Can't make it :(
    Ah well....
  6. moose
    moose What's a Dremel?
    12 Mar 2001
    sv_password didnt do the trick? Best bet is to set it up in server.cfg
  7. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    i might pop in for a bit if i remember
  8. Duronboy
    Duronboy Minimodder
    12 Jul 2001
    ill be in at about 9ish, my name is ^X^Sp00n so i fu see me make sure u say hi :D
    ne1 know the command in console for the pasword when u try to connect ot he server?
    ie: 213.213.54.54:27015............. where does the password go in this?
  9. Fatboy
    Fatboy Bored
    8 Oct 2001
    when u connect it says invalid password, you type:
    password mod <enter>
    then itwill reconnect with the right password ( i think )
  10. Jamie
    12 Mar 2001
    typ connect <ip> after you put in password ...
  11. Guest-16
    Guest-16 Guest
    I keep getting random IPs coming up saying: Password failed
    Maybe its my lan and its thinking that everyone else on it is trying to connect to me?
    Also what's the command to changemap in game? sv_changelevel cs_italy doesnt work??
  12. Fatboy
    Fatboy Bored
    8 Oct 2001
    To change map Type
    map cs_italy
    for example
  13. Celt
    Celt What's a Dremel?
    14 Jun 2001
    you don't need the sv_
  14. Jamie
    12 Mar 2001
    15 mins till pile in time ;)
  15. Mattt
    Mattt Minimodder
    12 Nov 2001
    FB check e- mail mattt
  16. moose
    12 Mar 2001
    to clarify, if you wanted to change to dust:
    changelevel de_dust
  17. acron^
    acron^ ePeen++;
    15 Oct 2001
    Wow!
    That was a great game there guys :)
    You MUST do that again sometime :)
  18. Fatboy
    Fatboy Bored
    8 Oct 2001
    it was well good, you should have stayed till the end to play scout wars :rofl:
  19. Duronboy
    Duronboy Minimodder
    12 Jul 2001
    HELL YEAH!!! that was kool, started of a bit flacky but the lag sorted itself out and ended up being a really good game. cudda done with smo more ppl though. o well alls well that ends well :D
  20. Guest-16
    Guest-16 Guest
    Lol yea. needs to be played later or earlier when 90% of ppl go out on the piss and network lag is less.
    Apart from that - much fun :)
    Celt - how do u get html webpages from those stats??
    also screenies:
    http://angelfire.lycos.com/super2/lewis/images/
    :) got the family tower photo! :D
    Kool - when u gonna run a Q3 server then? :)
