Displays 1440p stuck at 30Hz? What gives?
Discussion in 'Hardware' started by Spanky, 27 Dec 2019.
  1. Spanky
    Spanky Minimodder
    14 Apr 2010
    I know there will be a simple answer to this so i will ask.
    Bought a new TV. LG C9 OLED. And what a piece of kit it is!! However , having some issues with the resolution. Im running it on my gaming setup ( Ryzen 2600 / RTX 2060 ) .
    Native desktop obviously 4k and size set at 200% . I can set it at 1080p 120HZ no worries , 4k 60HZ no worries ( for now anyway as a Gsync update coming very very soon and will go 120 ) but when i try 1440p its stuck at 30 Hz??
    Now, i know the panel is capable of doing 1440p 120Hz ( maybe after the next firmware update ) but surely it can do 1440p @ 60Hz?
    What would it be thats stopping me from setting 1440p 60??
  2. RedFlames
    23 Apr 2009
    Limitations of HDMI?
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    Both the LG C9 and the RTX 2060 support HDMI 2, so that shouldn't be the problem.
    However beware junk like AV Receivers, Home Theatre systems etc, those often use ancient HDMI versions. So make sure it is literally GPU - HDMI cable - TV.
  4. faugusztin
    11 Aug 2008
    Download and run https://www.nirsoft.net/utils/dump_edid.html . It will tell you what resolution modes/refresh rates the TV offers to your device.
    For example, for mine it says:
    Code:
    Active                   : Yes
    Registry Key             : DISPLAY\GSM5B09\5&c3e9284&0&UID37126
    Monitor Name             : LG Ultra HD
    Manufacture Week         : 7 / 2017
    ManufacturerID           : 27934 (0x6D1E)
    ProductID                : 23305 (0x5B09)
    Serial Number (Numeric)  : *********
    EDID Version             : 1.4
    Display Gamma            : 2.20
    Vertical Frequency       : 40 - 61 Hz
    Horizontal Frequency     : 135 - 135 KHz
    Image Size               : 60.0 X 34.0 cm (27.2 Inch)
    Maximum Image Size       : 60 X 34 cm (27.2 Inch)
    Maximum Resolution       : 3840 X 2160
    Support Standby Mode     : Yes
    Support Suspend Mode     : No
    Support Low-Power Mode   : No
    Support Default GTF      : Yes
    Digital                  : Yes
    Supported Display Modes  :
         640 X  480  60 Hz
         800 X  600  60 Hz
        1024 X  768  60 Hz
        1280 X  720  60 Hz
        1152 X  864  60 Hz
        1280 X  800  60 Hz
        1280 X 1024  60 Hz
        1600 X  900  60 Hz
        1920 X 1080  60 Hz
        3840 X 2160  60 Hz
    Another alternative is the tool mentioned in NVIDIA customer help pages :
    https://nvidia.custhelp.com/app/answers/detail/a_id/2867/~/how-do-i-capture-the-edid-of-my-display?
  5. Spanky
    Spanky Minimodder
    14 Apr 2010
    Its a direct cable. The cable i have is a few years old possibly could be the issue?
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    There are 4 different types of HDMI cables:
    • High-speed with Ethernet
    • High-speed without Ethernet
    • Standard-speed with Ethernet
    • Standard-speed without Ethernet
    (although since next to nothing makes use of Ethernet over HDMI we might as well say there are two)
    If you found some old one in a drawer it could well be that it is an old one.
