146% Wavemaster
Discussion in 'Project Logs' started by Dezjay, 5 May 2005.
Where should the 1/2"wavemaster be ??
Poll closed 16 May 2005.
  1. TOop
    67 vote(s)
    54.9%
  2. Bottum
    55 vote(s)
    45.1%
  1. Firehed
    15 Feb 2004
    I'm sure that's on the agenda lol
    You mean the LL prommy conversion kits?
  2. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i agree, since its both bottom pieces it looks a lil wierd with both next to eachother :)
    it would be cool to have used the door part that way u can open it and see all the cool w/c stuff (put plexi where the bay covers would be)
  3. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    i'll make some bottum and top pics tonight.. The gap will beclosed the top plate of the 1/2" isnt on it right now.. The blue fan controller will be red 1 only had to get it in the case for an lanparty..
    the door idea is pretty cool i have tought about it i should have 2 cut the door and that is one thik plate....
    Maybe i'll cut in and place it in de the bottum of the top case.. I really would like the septup box on top so i dont get air in the rads..
  4. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    how about an enermax 660 watt psu
    and please place the ½ wavemaster at the top of the other one. it will look cooler
  5. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    or asetek vapochill
  6. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    and by the way kepp a clean color theme
  7. morishani
    morishani What's a Dremel?
    29 May 2004
    Nice, im subscribed.
  8. Dezjay
    10 May 2004
    how do you mean? you like it ? or not ?
  9. Rufus-Seal
    Rufus-Seal Guest
    Agree :)
  10. Dezjay
    10 May 2004
    My supplier gave this as an option to make the bottum and top to disconnect with out making everyting wet :)
    I'm not sure if they only connect to the hose or to the casing as well....
    the wicked babbelfish translation:
    Reciprocally automatically locking off clutch This clutch makes possible to separate it connections in the filled system, without suffering thereby a leakage loss. Ideally when using an external radiator. The integrated valves of the clutch close the supply when opening the clutch automatically on both sides nearly at the same time. When putting in they are automatically again opened. Therefore only extremely small leakage losses can occur. The clutch can be connected without further parts with our plug&cool-Schlauch. The clutch is pressure resistant up to 35 bar, certified temperature range -20°C to +100°C. All individual parts out not rusting materials. Larva in Germany.
  11. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    replace all other led's with red ones
  12. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    I like it at the bottom more becuase you can attach it (stupid excuse) but it's easier too for transport
  13. Hilenaluna
    Hilenaluna What's a Dremel?
    6 May 2005
    mmm on the top will be better, i think...
    nice idea if someone have twins case. I have 2 wave, one black modded and a silver one unmodded that take powder in my garage...may be a soluction for make a waterstation with the same style :thumb:
  14. Dezjay
    10 May 2004
    k took some pictures... so what is it going 2 be top or bottum.
  15. Kverna
    Kverna What's a Dremel?
    6 Jun 2004
    IMO the extra box is best under the case. Because the "line" is continued instead of broken off and started again on top. Haven't studied the post, sry :wallbash: , so have to ask: Are you going to paint the case(es) ?
    EDIT: Forgot an "a"
  16. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Deffinately bottom - allthough it does look a bit odd if you intend to keep the bottom half case looking stock like that.
    An idea to ballance things out might be to remove the 'gravestone' on the original case, and cut off the lip it was mounted on to flush with the curve in the front of the case. This would make it look more like one big case, isntead of a normal Wavemaster with two bottom sections.
  17. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    this looks best :D :thumb: :cooldude: :naughty: :rock: :hip: :eeek: :) :dremel: :jawdrop:
  18. kickarse
    6 Oct 2004
    lol... he's right the line looks better with it at the bottom... plus you won't have to fix the gaping hole that it leaves
  19. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    i like it on top!
  20. Dezjay
    10 May 2004
    i really think this is funny... i asked about everboy i saw this day and the results were 50/50..
    I think the bottom lookss better.. I like the way it looks with 2 bottom sections.. the gap between the bottom will befilled with red uv plexi :) içant mod this weekend because i have a lan party..
