146% Wavemaster
Discussion in 'Project Logs' started by Dezjay, 5 May 2005.
Where should the 1/2"wavemaster be ??
Poll closed 16 May 2005.
  1. TOop
    67 vote(s)
    54.9%
  2. Bottum
    55 vote(s)
    45.1%
  1. Dezjay
    Dezjay New Member
    10 May 2004
    Update 15 May 2005
    Because a car is proper finishd (what is the inspiration).. the pc has to look cool in the inside... so..... there must ben NONE or as few possible wires visible.
    Point1 was the removal of the intake fans. So the hdd's can me inserted further in the case.
    There were fans first:)
    The HDD will end at the end of the 3,5" cage
    Cut some metal to fit the mobo
    Fitting,cutting,fitting,cutting etc etc
    Done the same for the Drivecage;'s and the PSU :)
    It will be finishd with some nice...... :)
  2. Firehed
    15 Feb 2004
    That mesh is quite different, good work! I just hope it's easy enough to take out for when you have to change components...
  3. Dezjay
    Dezjay New Member
    10 May 2004
    well its not easy but it is possible..
  4. Dezjay
    Dezjay New Member
    10 May 2004
    Restart :)
    HI,
    haven't done much due some privat issue's and work...
    The other (allmost last) stuff came in...
    The cuplex XT cpu cooler.. really a nice block.. good design..
    The other bracket for the chipset cooler... this one allows the cooler easy on the chipset the only problem is that the chipset. it can not been mounted straight...
    The innovatek eheim 12v pomp..... really a nice one hopefully it will be good enough for the 2 rad etc.
    The fake leather (in dutch it's called skai dont know what it is in English) My girlfriend was so kind to buy it for me.... it's really exact the color i want and it's really thick.. This will be used to hide the metal of the stealth plates
    Not really a big update but i got to start modding now :) stay tuned
  5. Sva4g3&*
    Sva4g3&* New Member
    15 Jun 2004
    Lookin good, and what's that magazine in the left side of the last pictures. Looks like a spread eagle from here.
    Oh well, I guess you can get bored and lonely while modding :worried:
    :hehe:
    -Rob
  6. Dezjay
    Dezjay New Member
    10 May 2004
    lol.. its a local magazine from the Zoo...
    Man you guy;s notice everthing :) pic of girlfriend.. magazine :)
  7. mediacoretex
    mediacoretex New Member
    28 Feb 2005
    nice water cooling equment how much did it cost u for it
  8. mobius9
    mobius9 Member
    4 May 2004
    vinyl leather I believe. I made some pillows out of that so I can sleep during class.
  9. hobbs
    hobbs New Member
    24 Jun 2005
    looks realy good, keep it up!
  10. Dezjay
    Dezjay New Member
    10 May 2004
    Update 20 Juli 2005
    quick update @ work
    The power supply fan's will be replaced with white led fans.. All the led's in the fans wil be white.. little things will be red.. don't think that all lighting looks ok in red when the case is done
    Update 21 Juli 2005
    Because of the mobo coverplate it will get warm... to create some cooling for the mobo i thought of the crossflow fan.. but it is to big to fit in the wavemaster so....
    Crossflow fan disassembeld
    A part cut off... now let's see if we can assembel it again :)
    Bit unclear to see but every section of the crossflow fan has the same plate as the end... so.,. chop it off and put it back to gether :)
    The following thing to do.. make the housing fit :p
