Modding 15 inch side screen
Discussion in 'Modding' started by Montspy, 30 Jun 2009.
  1. Montspy
    Montspy What's a Dremel?
    28 Feb 2009
    Hi !
    I recently bought an Asus 22" wide screen to change my old Dell 15" but the second output of my graphic card is damaged so I can't use it. That's why I want to reuse it like a "Side screen" on my (old) PC (Dell Dimension 5000 .. erk)
    Here is the case : (already modded (my first mod ever :D ))
    And the screen which is incredibly durty, isn't it ?
    Panel : front
    Panel : back
    PSU and screen controller :
    I added a longer power input :
    I'm actually searching a LVDS 20-pin cable to change the one which is actually plugged-in because it is too short (about 3 inches) and I need a longer one (about 8 or 9 inches).
    Like this one :
    Bye !
  2. ry@n
    ry@n Minimodder
    31 Aug 2005
    Nice mods!
    So what are you planning to do with the screen now thats its minus its housing?
  3. jhanlon303
    7 Sep 2006
    Dells are really easy to mod with. The plastic is just for show and the bottom buttons are held on by the small ribbon cable.
    Side panel mod, test bench mod, or get stupid and do this:
    Really hack off the apple peeps.
    I love Dell 15s, built like a brick, interchangeable like a Chevy.
    Nice small monitor.
    Put it in the side panel door, I'll search for a long LVDS cable for you.
    john
  4. Montspy
    28 Feb 2009
    Thanks ry@an !
    Haha ! I love your iMac hack ;)
    > ry@an : I will cut the metal structure to fix the LCD panel on the side of my PC case.
    > john : I agree, 15" Dell are BIG bricks and easy to disassemble. Thank you for the LVDS cable !
    Just a question : Why does small lcd kits (8.4" or smaller) are more expensive than a real 15" LCD screen with VGA and DVI ?
    Bye !
    Montspy.
  5. Montspy
    28 Feb 2009
    Some work have been done :
    I installed the psu board on the top of the case (need to fix it with long screws but not for now) :
    I also modded the big metal block to fix the lcd panel to the side :
    What it looked like :
    Need to cut on the black line :
    :nono: NEVER :nono: buy this dremel (Maxicraft) disks are bad quality :
    Before cutting and a half cut after :
    What it looks like now :
    Assembled with the LCD panel :
    After drilling all the rivets, I can open the left side :
    Definitive place :
    Screwed (I love Meccano ! :D ) :
    To do :
    - Find a LVDS 20-pin (thank you john).
    - Make the OSD buttons cable and the inverter cables longer.
    - Adapt the plastic to fit with my case.
    Comments are welcome !
    Bye !
    Montspy
  6. jhanlon303
    7 Sep 2006
  7. Montspy
    28 Feb 2009
    Today I extended some cable : backlight inverter (2*2), control buttons to the board (8) and finally the LVDS cable ! (20) Which was too short, of course, so I've re-extended it another time grrrrr....
    Here are pics :
    Testing screen :
    Hidding cables :
    Proper install :
    The board :
    To do :
    Bye!
    Montspy.
  8. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Sweet! Nice work! I've been wanting to do something similar for a while, but have been diverted. I also have an old monitor with the normal IEC power cable (as opposed to the ones with the power brick and unique cables.) My thought was to not have 2 power plugs, but rather take power directly from the PSU's input by tapping into it by soldering a long thick gauged set of 3 cables to the power inputs for the LCD.
    How are you connecting the signal (video) cables? Are you going out and then in again from the graphics card, or did you figure out some way to tap it internally. I really want to keep the cables internal and not show it.
  9. Montspy
    28 Feb 2009
    Thank you !
    The VGA cable is actually going out and is plugged to the board (on the top of the case) but I think I'll make something to hide it. I will take power from the power brick of the PSU too.
    Bye !
    Montspy.
  10. Anders
    Anders What's a Dremel?
    28 Aug 2009
    hi
    Nice mod montspy.
    I have a little question, a have a lot of does lvds cables 20 pin, 14 wires.
    Is it possible 2 cut a lvds and convert it to vga ?
    or do I have to buy some converter for it ?
  11. Montspy
    28 Feb 2009
    Thanks,
    If I understand, you want to solder wires between a LVDS 20 pin connector to a VGA connector ?
    I'm not sure it's possible but here is the VGA pinout.
    Maybe you can find the LVDS 20 pin one and see if it's possible.
    I used the original board to transform the signal between VGA to LVDS so I don't know.
    Sorry.
    By.
    Montspy.
  12. Elton
    23 Jan 2009
    Not bad at all. You've somewhat inspired me to get off me lazy bottom and put an NEC Multisync LCD1860NX into my HAF...
  13. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Nice little mod you have going there.
  14. Elton
    23 Jan 2009
    Now you really have an excuse to stare at the computer.
