Displays 16:10 vs 16:9 Monitor
Discussion in 'Hardware' started by RedCasino, 19 Feb 2011.
  1. GoodBytes
    20 Jan 2007
    16:10 monitor is the idea size for all purposes. As programs has it's tool bar on top, status bar at the bottom, and usually you have the task bar at the bottom as well. The extra height doesn't make you feel boxed-in with your software (limited work space).
    16:9 monitor advantage of that SELECT movies won't have a small black bar at the bottom and at the top. The rest all with, as every movie is film in many different aspects ratio, depending what the director wants.
    Games won't be affected. It's been countless years since games fully support 16:9, and 16:10 games, without any hacking. It was true back in 2001-2005 as most people still used CRT non-wide screens, but not anymore.
    You should not see any FPS drop by going from 1920x1080 to 1920x1200, assuming you have a decent Nvidia or ATI graphic solution, which you perfectly do. Heck with that GPU, you should be able to play games at 2560x1440 and even higher no problem (60fps+), if you wanted to (with the right display).
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    As above. If you do find a game that doesn't support your resolution, just google "nameofgame widescreen" and you're sure to find a fix for it.
  3. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    16:10 is far superior IMO.
    When you are reading things, it means less scrolling. When you are viewing non-widescreen stuff, you get a bigger area. If you have a non-widescreen games, it will scale better (as an example, a 1920*1200 screen can also be a 1600*1200 screen with borders).
    Apart from cost, there is no good reason to give up the extra pixels.
  4. donok
    donok Every Little Helps .....
    16 Feb 2011
    Great thread. I need to choose from dell u2711(2560x1440) v u3011(2560x1600)
    There afew hundred quid price difference for 160 extra pixels vertically.
    Difficult to judge as I cant find anywhere that stocks them to go to to see them in real life
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I've always hated 16:9 screens. They are OK as long as you are watching movies, but as soon as you want to read something they feel cramped.
    The reason 1080 screens are so popular is that people recognize the number from the TV industry (where 1080 is decent). The standard made for computers are actually better... :rolleyes:
  6. RedCasino
    RedCasino What's a Dremel?
    19 Dec 2010
    Just to look at other sites to get a mixture of opinion, and I think 16:10 does 'win' the debate, especially after I saw these images. >Another Website<
    Thanks for the help guys and girls!
  7. mpe91
    mpe91 Wait... Wha...?
    8 Dec 2010
    The difference between the first and last three images on that site will be exaggerated because the 16:10 shots has the task bar hidden, and the 16:9 has it showing.
    As for my current choice, its currently 23.6" 1080 (16:9) screen and I couldn't be happier with it. Also, I can't say that I notice any of the issues that people are mentioning about lack of space, although that is probably more to do with moving from a laptop screen. :p
  8. Smilodon
    25 Mar 2003
    There is no doubt that 16:10 is technically better than 16:9. The numbers speak for themselves. The only discussion is really whether or not it's worth the price difference. (Unless we look at high-end displays which often only come in a 16:10 flavor)
    edit: mpe91: Fantastic avatar. :thumb:
  9. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    I've added the emphasis to the quote, as it's the crucial factor IMO.
    I bought the Dell U2410 last month - certainly not one to consider unless you've got a spare £450 to hand.
    But I bought it because of the resolution - 1920x1200. Some older games I still play don't support widescreen resolutions - C&C Generals being a good example. But it does support 1600x1200 - a resolution the U2410 can handle natively as it has an aspect mode that maintains the correct aspect radio with the necessary black bars on the sides. Some of the older C&C games only go up o 1024x768 but will still fill the same 4:3 part of the screen in aspect mode.
    I'd say it depends on how old the games are that you want to play and what resolutions they support - personally I prefer to avoid mods that enable extra resolution modes which made the decision easy for me.
    Blu-Rays look fine with the added black bars - they're not as dark as the bezel but hardly a problem.
    Depends on your intended use but the reasons I gave for the OP and my own purchase of teh U2410 were 1600x1200 resolution support - the U2711 can comfortably support that so I'd save teh extra cash - 1440 is more than enough vertical pixels IMO for most games and you might be able to save a little on the necessary GPU you would need for 2560x1600.
  10. donok
    16 Feb 2011
    That's the same way I feel. Save the cash to spend on system but I'm not a upgrader. I'm a buy not and play until it's broken kinda persOn. Plus the monitor should last at least 5 years. Worthy investment ?
  11. wyx087
    15 Aug 2007
    as i've said earlier, if you are doing productive work, the 30inch is worth it.
    otherwise, just get the 27inch, not that much difference in screen real-estate.
    just FYI, if you want to play 4:3 games, with 2560x1440 monitor, you can use 1920x1440.
  12. donok
    16 Feb 2011
    But you can buy 2xu2711 for the price if the single u3011- (remember I don't pay vat)
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I love my 16:10 monitor, it's really nice when editing photos or videos and I don't see a difference in games. The only thing I don't like is the black bars in movies, it's not horrible but you do notice it.
  14. GoodBytes
    20 Jan 2007
    Black bar in games?! I don't have any black bars.
    You probably not setting your game resolution properly.
  15. The_Beast
    21 Apr 2007
    My mistake, games are just fine, it's the movies that almost always have the back bars
  16. Deders
    Deders Modder
    14 Nov 2010
    Most movies are going to have black bars anyway.
  17. GoodBytes
    20 Jan 2007
    Yup, most movies have black lines even if you have a 1080p displays.
    Few movies are filmed in 16:9
  18. donok
    16 Feb 2011
    prices from scan
    u2711 is £580 exc VAT
    u3011 is £999 exc VAT
    i really cant justify the near doubling in price for 3" more and a hundred odd vertical pixels
    unless theres something im missing?
  19. Cei
    Cei pew pew pew
    22 Mar 2008
    I love my 27" (okay, it's an Apple Cinema Display, not a U2711H, but hey, I hate Dell's AG coating), and having owned a 30" in the past, I don't miss it. Yes it's 16:9, but it's huge and the extra vertical space didn't mean much.
