Memory 1866mhz vs. 2133mhz
Discussion in 'Hardware' started by ModaRobby, 2 Jan 2013.
  1. ModaRobby
    ModaRobby What's a Dremel?
    5 Aug 2009
    1866mhz DDR3 with 10-10-10-27 timings
    or
    2133 DDR3 with 11-11-11-30 timings?
    Which is better? I feel like my PC loaded the desktop faster when I had 2133 running.:sigh:
    Kingston HyperX T1 (the pair I have overclock to 1866 10-10-10-27 from 1600mhz)
    Kingston HyperX Predator
  2. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    As far as I am aware, you'll see Very little difference in the real world and only really worth upgrading if you are benching.
    If you already own the faster ram use it, if not, I wouldn't spend the cash tbh.
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    You wont be able to tell the difference, I would just go on price, although if you have an APU, they seem to gain more of a performance benefit from higher frequency ram.
  4. ModaRobby
    5 Aug 2009
    I figured I wouldn't actually notice anything but I was just wondering which one would technically be better seeing as how I own both. I'll just stick with the faster RAM. Thanks :)
  5. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
