Hi, I have a 12U Flight case similar to this: http://www.flightcasewarehouse.co.uk/music/typeproducts2.asp?id=2887-2604 I'd like to add my PC to the flight case but I'm having trouble finding a suitable rack-mountable case with a depth of 500mm. Presently my PC comprises of: ASUS P6TD Deluxe Corsair H50 Saphire ATI 5770 HD 1 x SSD 1 x 3.5" HD 2 x DVDRW drive I've seen cheap "short" (460mm) 4U cases which would fit the flight case but I've read that fitting a full sized graphics card can be difficult. I was also wondering if a 4U case is sufficient for airflow? Is it worth considering a 5U case? If anyone has ideas or suggestions for this I'd be very grateful. Thanks for reading, Shanksy
http://www.xcase.co.uk/X-Case-RM-404s-4u-short-rackmount-p/case-xcase-rm404-v2.htm Job done Ignore the reviews. The reviews are fromn the old original model which needed a Dremel to allow long card support
Have you sewen the Lian li PC-C32 cases they are very nice looking with hotswap caddies in one of them, there is the 33, 34 too. Although their are around £150.
