19" TFT buying advice?
Discussion in 'Hardware' started by Lestat, 20 Dec 2004.
  1. Lestat
    Lestat New Member
    16 Sep 2004
    Hi all,
    Since its Xmas is round the corner, I decided to treat myself to a 19" TFT :hip: The only problem is that I haven't got the foggiest of which one to choose! :sigh:
    I was originally going to choose the Iiyama E481S-B, but checking some reviews on PCPro :
    MAC User review
    PC Pro Review
    Both say totally different things?! Macuser, says its basically crap image quality and loads of lag, whereas PCPro says its the dogs ******!?
    Looking around some other shops, I noticed that Iiyama are bringing out another model : E485S-B which has a 20ms response time. So should I wait a little longer for this one to come out?
    I just need a good TFT to do some surfing/watching DVDs/Doom 3/HL2/NFSU2 without any ghosting or lag. I know there are quite a few 19" with less than or around 16ms response times, but just wanted first hand experience on the make and model you guys use.
  2. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    I've been warned not to buy a 19", because the resolution isn't any greater than on a 17" screen. So you're not getting any more space on the screen, just more space on your desk.
  3. Loz
    Loz Blah Blah
    16 Apr 2002
    I've got an LG 1915S. 12ms response, 1280 x 1024 resolution, respectable contrast and brightness, no dvi but it looks fine to me. Makes my CRT look blurry and nasty :D
    It used to be available all over the place, but I can only find it at Scan now. Maybe you'll have more luck. Best of all is the price tag, it's well under £300.
    Edit: in response to TekMonkeys concerns, it really depends what you like. My 19" CRT supports 1600 but I prefer to run it at 1280 anyway. Things look too small to me otherwise.
  4. TekMonkey
    6 Dec 2002
    But why spend the money on a 19" if you could run it at the same resolution on a 17"? It's a waste of money IMO.
  5. JuMpErFLY
    JuMpErFLY Member
    13 Mar 2003
    The screen is bigger, which is definitely more important for playing games and watching movies than resolution IMO. I wouldn't call it a waste of money, you're getting a bigger screen, obviously this isn't a benefit to everyone.
  6. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    whats your budget, and whats your video card
    cus theres no point in getting a monitor which has a native res of 1600x1200 if you have a crap graphics card which struggles like hell at that res.. also, its a waste to get a 19" w/ only 1280 x1024 res if you have a rather high end card...
    id say 16ms response maximum.. so you wont have to worry about ghosting/lagging
  7. Lestat
    Lestat New Member
    16 Sep 2004
    Heya,
    I've got a Asus 9800XT VIVO, According to Windows it can do 3200 X 1600, LOL widescreen which I don't think I can afford for the time being :p
    Budget is around 400 quid, but there are loads going for about 350ish... The one that caught my eye was the IIyama 19" ProLite E485S-B for only £279? Its got 20ms response rate, the previous model E481S-B has 25ms, and apparently has no ghosting whatsoever?
    Iiyama 19" Prolite E485S-B
    Forgot.. the TFT can do 1280 x 1024 / 75mhz
    I typically only do 1024 X 768 on my 17" Iiyama 413 monitor anyhow, just tried 1280 x 1024 on it, and everything looks sooooo small!! :( Hopefully the bigger screen size should make it viewable :) I'll need to pop down to Dixons/currys/PC World to see the screen res first hand anyhow.
    Pah.. choices choices!! :(
  8. tamffc
    tamffc New Member
    5 Oct 2003
    ive got a viewsonic vx192. dvi input, 12 ms response time.highly recommended
    bought last week from "lowest on the web" all stock has sold out now,a great monitor for £360. as good as my old triniton crt.
  9. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    Friend of mine just bought a 19" Sharp and after seeing pics of it and from what he's said on it, I'm considering one myself :) . They look shiney too.
    Personally though, Iiyama all the way :thumb: .
  10. scotty6435
    scotty6435 New Member
    4 Sep 2004
    Got a 2 year old iiyama 19.1" TFT myself and going back to a 17" really makes a difference. the extra few inches really makes it easier to view past 2 feet.
  11. Lestat
    Lestat New Member
    16 Sep 2004
    Sheesh 2 year old 19" IIyama?! What model is that?
  12. Krashnicki
    Krashnicki New Member
    19 Jul 2004
    I don't know what your budget is but I just bought a new apple 20inch display and it is awsome. The redesigned apple displays now come with a standard dvi connection so it can be used on a pc without an adaptor.
  13. Lestat
    Lestat New Member
    16 Sep 2004
    Heya mate,
    My budget is only around 400 quid. Even though its an inch bigger, it'll prolly cost me another 200? considering its Apple brand as well, perhaps another 200 quid ontop? :duh:
    How much did your Apple 20" TFT cost?
  14. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    They cost, erm...£999
    :worried:
    <A88>
  15. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    you get a discount if you're a student though. apple displays, finally, have become worth owning. the old ones were godawful.
  16. Lestat
    Lestat New Member
    16 Sep 2004
    OMG!? Give me your address, and let me know when your family is out of the house :naughty:
    Sheesh you could get nearly 3 19" TFTs for that price :-/
  17. Lestat
    Lestat New Member
    16 Sep 2004
    Even with a discount, unless they gave 60% off or something, its still way out of my budget! :(
  18. scotty6435
    4 Sep 2004
    It's the AS4637UT BK. It was a £650 upgrade on a sweet 19" sony CRT back in 2002. My wallet still hasn't recovered but my eyes are happy :)
  19. Lestat
    Lestat New Member
    16 Sep 2004
    I hear that Iiyama model that you've got is the only one available that does 1600 X whatever. I can't find that model anywhere on the net though :( discontinued :( Its odd that an older model can do those resolutions, whereas the new ones can't? :-/
  20. Kermet
    Kermet [custom title]
    18 Feb 2003
    I'm waiting for some reviews of the Hyundai ImageQuest L90D+. Quite pricy but then it only became available today and have only seen it at OCUK...
