1GB of good or 2GB of mediocre
Discussion in 'Hardware' started by SaII, 17 Dec 2006.
  1. SaII
    SaII What's a Dremel?
    7 Jun 2006
    I do some light gaming, so I'm wondering if the list of games below benefit from budget(ram other then D9s) 2GBs of ram or should I stick with 1GB of uber ram(D9s). the price of overclocking ram is on the rise and I'm not willing to give up $300-$400 for 2 frames. (this is for reference to build my machine)
    Machine:
    E6300(should be OC'd to 3.5-3.6 with D9; without D9, should be less then 3.5)
    P5B-D(no Wi-Fi)
    7900GT(should be OC'd to GTX speeds)
    Game:
    F.E.A.R (original and expansion)
    Quake 4
    UT '04 and '07
    C&C zero hour
    Company of Heroes
    Guild Wars (any)
    Thanks
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    2gb. More > faster. That, and you can run a divider, which will be really useful for clocking.
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Yep, go with 2Gb. :)
  4. SaII
    7 Jun 2006
    but I'm thinking of running 1:1 at 500MHz for FBS OC, CPU OC and ram OC.
    or am i getting the fundamentals wrong?
  5. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    2Gb & use a divider if you have too
  6. SaII
    7 Jun 2006
    I'm planing to use 1:1 divider and up my ram to 500MHz
    like i said in my last post :blah:
    but 2gb of ram that can get me to 500MHz are over 300$
    so I'm not going to spend that much.
    will I see a giant difference in the games I play between 2GB and 3.1GHz to 1GB and 3.5GHz
    (This is all estimate)
  7. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    some games will see a big difference when running on 2gb compared to 1gb. no games will have any difference when running 3.5ghz instead of 3.1ghz
