1kw power supply
Discussion in 'Hardware' started by Masterchief, 23 Feb 2007.
Thread Status:
Not open for further replies.
  1. Masterchief
    Masterchief Banned
    23 Feb 2007
  2. trig
    trig god's little mistake
    10 Aug 2006
    what the heck are you running that you need that much power?
  3. Masterchief
    Masterchief Banned
    23 Feb 2007
    qx6700
    8800gtx 630/2000 sli
    11 sas drives + controller
    8gb ram
    striker extreme
  4. Major
    Major Guest
    I think someone has too much money. :)
  5. DMF
    DMF What's a Dremel?
    27 Dec 2006
    Sweet system y didnt you go even more over the top and get 4 opterons? You water cooling all of it or just air? Wat case u got it in? Think that a 1000 watt one would be good incase you wanna add more stuff.
  6. specofdust
    specofdust Banned
    26 Feb 2005
    620-700W will do fine for that system.
  7. trig
    10 Aug 2006
    yup...but what if someday he really wants to upgrade with another drive or 12?? :D
  8. Masterchief
    Masterchief Banned
    23 Feb 2007
    no not really, because hard drives only last 5 years. and thanks fore the advice dmf but i don't know an os that supports more then 4 cores
  9. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    Some do.
  10. Masterchief
    Masterchief Banned
    23 Feb 2007
  11. trig
    10 Aug 2006
  12. Masterchief
    Masterchief Banned
    23 Feb 2007
    LoL very handy thx
  13. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    yeah but with a massive rig like that a normal size psu would look small go for the MASSIVE one you know you want to lol that is a great system i am so envious
  14. trig
    10 Aug 2006
    i am envious of your avatar :naughty:
  15. sk8ter646
    4 Oct 2005
    yeah shes a hotty lol but thats a bit off topic lol
  16. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    www.deadeyedata.com
    Silverstone ST85ZF
    Coupon code: JONNYGURU
    There, ~$200, and enough for whatever you throw at it.
    Recommendations in this thread: Athena: it's just topower. pass. Enermax: Pass. Soon-to-be-recommended tagan: It's just topower. pass.
  17. Masterchief
    Masterchief Banned
    23 Feb 2007
  18. DMF
    27 Dec 2006
    Yeah man the koolance one is nice you should get it cause its an exotic piece of hardware. Got any pics of ur system?
  19. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    I'd second BBQ. Or the Etatis 850w unit (same internals as seasonic, different wiring loom)
    If you have money to burn on a PC, then at the end of the day the decision is yours. Seem's utterly pointless to spend money where you don't need to though. Just ask yourself, will I use and do I need what I'm buying. (The answer to that Koolance PSU is no. Tad will probably have something to say about the SAS drives too.)
    What's your PC going to be used for?
  20. ComputerKing
    8 Sep 2006
    DUDE ...
    One Word , Enermax Galaxy 1K , And no thing can be like this Bebe
    Silent , Strong , Safe , I swear I like it , I have one of it , GO with it
    Good luck , BTW : Nice system :D ROCK ON
Thread Status:
