1st Attempt : Stealth UV
Discussion in 'Project Logs' started by J-Nonymous, 16 Jun 2005.
  1. J-Nonymous
    J-Nonymous What's a Dremel?
    16 Jun 2005
    After much searching and hunting...I say, this is 1 active forum on case modding...
    Well first...I'm new to modding...and all those case I've seens over these few years really make me go gaa gaa over it. So I've decide to start on mine.
    Here's the case I will be working on...
    Simple, Plain and stealthy look...
    Front cover opens all the way to the side
    Top = Left, Bottom = Right Panel
    My idea will be spraying the inside with UV lime green, sleeving and spraying my PSU wif UV red. For the side and top panels...the left I've decided to cut accordingly...whereas the right panel needs some ideas frm you guys...
    all suggestions/critiz are welcome =)
  2. Vazzini42
    Vazzini42 What's a Dremel?
    16 Apr 2004
    i like that case, good choice
    maybe something to go along with the folding and opening of the front is a way to go
    Edit: i didnt have any luck with the spray on invisible uv paint, the kind that goes on clear and is supposed to glow a color under uv. Couldnt get it to glow under uv at all. Others may have had better luck.
  3. morishani
    morishani What's a Dremel?
    29 May 2004
    Looks good till now . good color choose - lime green & dark gray.
  4. J-Nonymous
    16 Jun 2005
    currently i have a couple of prblms with require some advice...
    1st rivets...i need to remove my top panel so i can spray the inside and drill the top panel for some ventilations.
    2nd, paints...i have a couple of flueresence green paint...but is flueresence = uv? kinda puzzles me...
    lastly...right panel...as seen in the pics...my side panels have ventilating grills...really spoils the look...no prblm for the left side...but the right side's grills happens to be in the way of the mobo tray...any suggestion for the right panel?
    initially, i wanted to juz cut ard the grills...and fit an etched acrylic and couple of LED to light it up...but later on find it kinda werid looking...
  5. ShinySwede
    ShinySwede What's a Dremel?
    6 May 2005
    When i removed the rivets on my wavemaster i just used an oversized drilbit, drilled one side away and then it poped out on the other side =) But it might be so that you dont have enough space for a drill idonno really...
    And i dont know if lighting the right side up with some leds would that bad idea, would look pretty good with some frosty sanded acrylic and some leds =) .....usually making these decision based on pics is pretty hard ...but youll figure it out=) ....
    Good luck on the project!!
  6. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Yes indeed. Rivets can easily be removed by drilling out the 'head'. When the head is of it just falls out. Make shure you only drill the rivets and not into the case itself. Beware that you have a plan for replacing those rivets, you can't use thos erivets again. Use something like bolts.
    The paint is difficult to say. Maybe the shop you bought it can tell it, or you can test it. Paint a piece of old metal and light it up with a UV lamp. My feeling tells me it;s not UV reactive, not many paints are. Good luck with your modding and welcome to the Bit-tech forum.
  7. J-Nonymous
    16 Jun 2005
    oh...i tot i've to drill the tail side...tat will put in difficult position...lolx...
    abt the paint...den tats bad...arghhh...
    thnkx for the ideas and infos...
  8. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    wow crazy window design!! Cant wait to see it cut. looking good :thumb:
  9. gebrek
    gebrek What's a Dremel?
    11 Apr 2005
    have i been hiding under a rock or something? cause i've never seen that case before... maybe i'm just not observant enough. Anyway, good luck with it.
    ...man, i really like that case...
  10. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    That's a wicked case, where did you get it, how much, etc etc... me likey!!
  11. J-Nonymous
    16 Jun 2005
    was surprise when i 1st saw it...i got it during a trip to Kuala Lumpur, Malaysia...looks kinda eye catching so i bought it...
    price tag....lolx malaysia$100...not sure abt the currency rate...singapore$ will be ard $47...
    think the company is not a famous 1...name of the casing is call G3...
    thnkx for the support =)
  12. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    According to XE.com, 100 Malaysian Ringgits = about $26 USD. or about 14 UKP.
    Looks like a cool case; I don't like casefront doors, but that's just me! The rounded windows look like they'll be great.
