Build Advice 1st boot, no display
Discussion in 'Hardware' started by hugo60, 7 Sep 2009.
  1. hugo60
    hugo60 What's a Dremel?
    28 Aug 2009
    Basically i have just finished putting together my 1st pc and when i power it up, the case and video card fans come on but no display will come up on the screen, monitor is connected to the motherboard as the slot is different to gpu. Any ideas?
  2. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    Are you saying that you've connected your monitor to the integrated graphics port on the motherboard?
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Umm, so you're saying that you have a GPU in an expansion slot but you're using the on-board GPU?
    In that case you might want to take out the expansion card, because i think integrated GPUs disable themselves if they detect an expansion card. Correct me if i'm wrong.
    Also, most (if not all) expansion cards come with a DVI-to-VGA converter, so you can use your VGA monitor with a DVI card.
  4. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Yes that's exactly what he has done.
    The computer will display through the graphics card if it is plugged in and onboard will be dissabled.
    You will need a VGA to DVI connector, one should come with the graphics card and use that to plug ithe monitor into the graphics.
    Should look like this
    If you don't have one you can run with the monitor plugged into the motherboard untill you get one but you will need to remove the graphics card.
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    ^Did i ninja you or are you backing me up?
  6. hugo60
    28 Aug 2009
    Ok i'll try that, :S looks like it didnt come with one.
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    That's odd. What brand and model is it?
  8. hugo60
    28 Aug 2009
    xfx 4890 bought from scan
  9. Slizza
    23 Apr 2009
    You sure did :D
    @ Hugo: you should check through your stuff again the card should have one with it.
    and other stuff like here.
    hugo60 likes this.
  10. hugo60
    28 Aug 2009
    That is the oc'd XXX version. Just found this "This card doesn't come with DVI to VGA converters." stupid me :l Guess its off to pc world, assuming they sell them. Lol...£20, maybe not. Shall i stick my 8600gt in for now then?
  11. antaresIII
    antaresIII tephigram
    25 Feb 2009
    Slizza!! you're really fenomenal!!!
    :rock: :rock: :rock:
    How did you guess from his not very good description???
    The culprit is also this forum, which does not allow posting attachments; I have 100 posts and still can't add half stamp!
  12. hugo60
    28 Aug 2009
    Booted fine with 8600gt, thanks for fast replies, will be ordering dvi/vga convertor from scan.
  13. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    You're welcome mate. Feel free to reward your helpers with some +rep.
    hugo60 likes this.
  14. hugo60
    28 Aug 2009
    While installing the heatsink im worried it may have slide around a bit, would this bugger up the application of thermal paste? Or do u think i'll be ok leaving it. I'd rather not have to take it apart again as it is a pain in the ass to fit lol.
  15. Slizza
    23 Apr 2009
    I think you should be fine mate.
    Once you are all set up and running do some tests by installing "real temp" and "Prime 95"
    Run them both for a little while and look at the temps.
    If you have any concern over them then report back here with the results.
  16. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Well done on your new build :thumb:
    Whats the spec of your new build?
    I imagine if you've gone from an 8600GT to a 4890 your in for a Treat :rock:
  17. hugo60
    28 Aug 2009
    Thanks, specs are:
    Phenom 2 X4 955 3.2ghz
    4gb Corsair XMS3 ddr3 1600mhz
    XFX HD4890
    Asus M4A785TD-M Evo
    Silverpower 650w psu
    320gb Spinpoint f1 hdd
    CoolerMaster CM690 case
    Looking forward to using it, slight step up from this pentium 4 lol.
  18. Slizza
    23 Apr 2009
    excellent step up from a p4!
    You will have fun with your new toy.
